DVI to HDMI
First post, by IMeganElisabeth
I’m wanting to know what I need in order to connect this PC (http://imgur.com/HmHdVUn) to an HDMI display. I have this adapter- (https://www.amazon.com/gp/aw/d/B00B2HP9T2?psc … search-keywords). Thank you so much in advance.
Will this work?
https://www.amazon.com/Rankie-Adapter-2-Pack- … &ref=mp_s_a_1_5
Reply 1 of 2, by cyclone3d
The adapter you already have should work just fine.
Just plug it into the HDMI port on the display and then use a DVI cable from the computer to the adapter.
The other adapter you linked to will also work if you want to plug it into the computer and then use an HDMI cable.
Now if you want to run DOS resolution stuff, you will need a scaler to go from VGA to HDMI... or DVI-I (analog) to HDMI.
That gets tricky trying to find one that supports all the old DOS resolutions and refresh rates.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 2, by dr_st
Up to FHD/WUXGA resolutions (1920x1080/1920x1200) DVI and HDMI transmit exactly the same signal. So passive adapters work with no issues.
