First post, by emosun
- Oldbie
lets talk about the 3870x2 because i have one and find it interesting. specifically the 1gb of vram it claims to have. I now understand the card works as such....
it's two separate 3870's each with 512mb of vram. ONE of those 3870's has two dvi outputs , the other has no outputs at all (hence why both outputs still work if you uninstall one of the gpu's in device manager).
Now when in crossfire mode we know that the vram does not combine , just the gpu's themselves. However.... the second gpu has it's own 512mb of vram that... surely must be used for SOMETHING.
Am i to guess that when you crossfire two gpus that the vram doesn't combine but DOES clone each other? Meaning both gpus have the same information in the vram?
