S3 805 86C805-P speed?
Discussion about old graphics cards, monitors and video related things.
Postby Baoran » 2018-8-15 @ 00:13
Does anyone know how would a VLB video card with a S3 805 86C805-P chip compare to other VLB video cards like for example tseng labs or cirrus logic cards?
Baoran
Re: S3 805 86C805-P speed?
Postby kixs » 2018-8-15 @ 00:16
Slower then Tseng and on par with Cirrus Logic 5426/28.
My Amibay: SALE | BUY - Updated on 2019-01-24
User avatar
kixs
Postby Nvm1 » 2018-8-15 @ 17:43
kixs wrote:Slower then Tseng and on par with Cirrus Logic 5426/28.
"Slower" is relative, it depends a lot on who made the 805 card and what RAMDAC is on the card.
Nvm1
Postby derSammler » 2018-8-15 @ 17:57
The 805 is a very slow card, probably one of S3's slowest. It was absolutely low-end and cut down to a 16-bit interface. Even the fastest 805, the 805i with interleaved memory at 2 MB, fails to beat a Trident TGUI9400. It's still faster than any ISA card, but not a very good VLB card.
derSammler
Postby Baoran » 2018-8-15 @ 18:25
I only have one vlb video card and I was thinking if I should get that S3 one as a spare for my 486, but if it is that bad it is probably not worth it.
Baoran
Postby kixs » 2018-8-15 @ 18:30
If it's for a good price, then get it. It was one of the most used card in VLB era.
User avatar
kixs
Postby Nvm1 » 2018-8-16 @ 13:29
derSammler wrote:The 805 is a very slow card, probably one of S3's slowest. It was absolutely low-end and cut down to a 16-bit interface. Even the fastest 805, the 805i with interleaved memory at 2 MB, fails to beat a Trident TGUI9400. It's still faster than any ISA card, but not a very good VLB card.
Some versions of the Trident TGUI9400 and 9440 are really fast cards, but the S3 805 is nowhere as slow as you depict it here. It was faster then alot of Cirrus Logic and nearly all older Trident cards. Mine was faster then my Tseng 4000AX card too. That S3 made faster cards is a fact I won't deny, if I look at the Trio32, 928 and 864 cards I also use :lol:
Biggest plus for the 805 is that it is very compatible, and even on LCD's most of the versions made look good.
Nvm1
Postby derSammler » 2018-8-16 @ 17:04
Nvm1 wrote:Some versions of the Trident TGUI9400 and 9440 are really fast cards, but the S3 805 is nowhere as slow as you depict it here. It was faster then alot of Cirrus Logic and nearly all older Trident cards. Mine was faster then my Tseng 4000AX card too.
The card was tested by me and others and it barely reaches 10 mb/s. TGUI9400 is a bit faster and has 2d acceleration, which the 805 lacks.
Also, as already written, the 805 was lowest-end with the host interface even cut down to 16-bit, despite being a VLB card. It *is* slow (only 911 and 924 from S3 were slower), if you accept it or not.
I did not say that there weren't slower cards made by others, but that was not the question anyway. I even wrote that it's still faster than any ISA card, so I don't see how I depicted it slower than it is.
derSammler
Postby Nvm1 » 2018-8-16 @ 19:51
Also, as already written, the 805 was lowest-end with the host interface even cut down to 16-bit, despite being a VLB card. It *is* slow (only 911 and 924 were slower), if you accept it or not.
Well, you literally write that it is a "very slow card", "absolutely low-end" and "not a very good VLB card". Only plus you give it is that it is faster then ISA cards (which is clearly correct).
That summed up it seems like the Oak card under the VLB cards, while it actually isn't that rock bottom in performance, and it is very good compatibility wise. It might be my way of interpretation but for somebody who is now searching for a VLB card and you can get a 805 for a decent price it certainly is a good choice. It will run with everything, albeit not the fastest.
And there aren't that many other choices anymore in the market with mainly Cirrus Logic cards and S3 805 cards going around here for decent prices if I look around on all websites.
Nvm1
Postby Eep386 » 2019-2-05 @ 06:38
805/i/p cards tend to vary widely in speed and picture quality, depending on memory speed, BIOS and RAMDAC. The speed also varies depending on whether you are running it under DOS or Windows. DOS/Mode 13h performance isn't stellar by any means, but is often improved by switching it into zero-waitstate mode. It edges out the best ISA cards with a 'good' implementation. Lesser implementations can be pretty sluggish. I owned a number of 805 cards and they seemed to do alright, though one with 80ns memory was a dog.
Windows performance is usually visibly better than Cirrus GD5426/5428 cards though, drivers and board permitting.
And yes, the 805 indeed has 2D acceleration. It's a Windows 3.x-era GUI accelerator. Provided the board's design doesn't hold it back, it usually visibly outpaces Tridents and Cirruses (not including better 5429 boards and later 64-bit chips) under Windows 95 with proper drivers (even though it wasn't really designed for Windows 95).
The TGUI9400 despite the name is NOT really an accelerator, it's a slightly improved TVGA9200CXr with a hardware cursor sprite, but no actual acceleration hardware beyond that. It's very similar in spirit to the OTI087X in that regard. The TGUI9420/9440 were the first 'real' 2D/GUI accelerators from Trident.
My synthesizer hierarchy: Novachord > DX-7 > YM2151 > YM3812 > CT1747/YMF262/YMF289 > CQM > PC Speaker > AudioPCI "FM" (retch)
User avatar
Eep386
Postby The Serpent Rider » 2019-2-05 @ 11:04
There's also 86C805-Q.
User avatar
The Serpent Rider
Postby Baoran » 2019-2-05 @ 15:28
I didn't get the card with S3 805 86C805-P chip. Instead of that I found a really cheap diamond stealth pro vlb card that has S3 P86C928 chips as a spare for my 486.
Baoran
Postby 386_junkie » 2019-2-08 @ 23:25
Yup,
Chalk up another thumbs down for the performance from S3-805, I had higher hopes for way back when... even in DOS using DRAM.
User avatar
386_junkie
Postby arncht » 2019-2-09 @ 08:28
For vga it is ok, for vesa one of the slowest. Here is a comparison:
https://docs.google.com/spreadsheets/d/ ... iQHPfTl4Xs
User avatar
arncht
Return to Video
Who is online
Users browsing this forum: No registered users and 2 guests
