First post, by Intel486dx33
What is the standard size of a Windows 3x .bmp file ?
I want to make some.
and what is the easiest program to use to make .bmp files ?
E.G
Photoshop
MS-Paint ?
etc.
16bit color ?
24bit color ?
etc...
Reply 1 of 8, by shamino
BMP files don't have compression. The file size in bytes is the total number of pixels multiplied by the color depth (in bytes).
So for example, 1024x768 with 8bit color is a 768KB file. 1024 x 768 x (1 byte)
640x480 256 color .BMP files used to be common, those work out to 300KB each.
High res images with more color get very inefficient without compression. 1600x1200 24bpp is about 5.5MB.
I'm not much of a picture editing person, but any paint program I've ever used has supported saving to BMP files. MS Paint is simple but very limited. I like Paint Shop Pro 4, but it won't satisfy every need. Irfanview is a more modern option than those, but I haven't used it for painting pixels much. Photoshop, Gimp, etc are complicated but if you know how to use them, they can do the most.
Reply 2 of 8, by leileilol
My 1993-94 preferred BMP program was Paint Shop Pro, including from before it became a Zsoft-inspired paint program at v3. It had decent processes for converting color depth as well
Reply 3 of 8, by Jo22
In terms of Win3.x gfx software, I also remember WinGIF, Graphic Workshop, Easel, etc.
Standard resolution was 640x480 pels, in either 16 or 256 colours.
Another form of BMP, called RLE, used some form of compression (run-lenght enconding).
https://docs.microsoft.com/en-us/windows/desk … map-compression
Last but not least, there also was WMF, the Windows Metafile Format.
https://en.wikipedia.org/wiki/Windows_Metafile
Edit: Also have a quick look what the Wiki says about the Windows system palette.
Especially "In 256-color mode, there are four additional standard Windows colors, twenty system reserved colors in total;
thus the system leaves 236 palette indexes free for applications to use."
https://en.wikipedia.org/wiki/List_of_softwar … 0-color_palette
Reply 4 of 8, by shamino
True, RLE formats are still fast to decode on old systems and can significantly cut down on file sizes if the images are hand drawn graphics (not photographs that change color every pixel).
I don't remember if Windows 3.x has any support for displaying them on the desktop though.
Edit: Also have a quick look what the Wiki says about the Windows system palette. Especially "In 256-color mode, there are four […]
It's been a long time since I used it, but I remember Paint Shop Pro having an option related to this. When scaling the color depth to 8bpp, I think it had an option for whether or not to interfere with the reserved portion of the palette. So that's one point in favor of PSP.
If you don't have need for really advanced features like Photoshop, then Paint Shop Pro would be my recommendation. PSP is simple enough but capable enough to hit a good sweet spot IMO.
Reply 5 of 8, by Jo22
I don't, either. WinGIF supported it, at least (just checked). 😀
Edit: Screen capture added.
    12.3 KiB
Reply 6 of 8, by Jo22
Now that I think about it, I remember a few more picture programs for Win3.x.
PhotoStacker Plus, iPhoto and ImagePals.
These weren't exactly popular, so I hope you don't mind if I add some pictures of them.
PhotoStacker Plus was interesting, since it supported a uniqe form of JPEG no other program supports (DPCM lossless).
It also can read more exotic file types, such as GEM and MSP (ancient Windows picture format).
    80.74 KiB
    PhotoStacker Plus
    19.27 KiB
    PhotoStacker Plus, reading an Windows 1.x/2.x MSP image
    61.09 KiB
    iPhoto and sample picture (magnified)
Reply 8 of 8, by Jo22
PS for Windows 3.1 is cool. Version 5.x also introduced that special brush/feather, or was it 4 already ?
Anyway, I also remember that CorelDRAW was popular, too.
IrfanView and XnView could run on Win32s, too.
Last XnView for 3.x was v1.50, I believe. 😀
