First post, by MKT_Gundam
There any problem to run socket 775 motherboards compatible with win 98?
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 3 of 6, by MKT_Gundam
I planning a dual boot win 98se and XP
For 98- Using a Voodoo 3 2000.
For XP AGP card- Fx 5500 or lame 6200 LE.
I will try to find a Radeon 9600 card at least.
Having two card cards will cause problems in Xp?
Reply 4 of 6, by oohms
shouldn't be an issue but glide wrappers are so good it's not worth putting a card that slow in a 775 setup
DOS/w3.11/w98 | K6-III+ 400ATZ @ 550 | FIC PA2013 | 128mb SDram | Voodoo 3 3000 | Avancelogic ALS100 | Roland SC-55ST
DOS/w98/XP | Core 2 Duo E4600 | Asus P5PE-VM | 512mb DDR400 | Ti4800SE | ForteMedia FM801
Reply 5 of 6, by MKT_Gundam
Using Glider wrappers will need a good and fast GPU? A fx 5500 will be powerfull enough to use?
Reply 6 of 6, by oohms
Glide is a very basic API.. a fx5500 should be fine
