First post, by Gahhhrrrlic
I've got a P2B 400 MHz setup with an 8500DV primary and dual Voodoo 2 SLI graphics. I'm using the latest version (4.6) fastvoodoo2 drivers on a fresh 98SE installation. Right out the gate the only thing I did was install the 8500 drivers from AMD's website (which for some reason show as a 7500) and then installed the voodoos manually per the instructions 1 at a time. They both installed correctly and show up in device manager (although I remember my wallpaper used to change before but now it doesn't) and when I go to display properties, advanced and Voodoo 2 tab, the screen briefly flashes and then no new content shows up in the voodoo tab (it still shows the content of the previous tab) and the entire window is basically crashed/frozen. This happens every time I try to access that tab but I have no clue why.
Anybody had this happen before?
