Faulty Voodoo 2?
First post, by DonutKing
I had a system with 2 12MB STB Voodoo 2's in SLI. Iuse past tense here as it appears only one of the cards is working and so no more SLI 🙁
One of the cards seems to work fine. The are both detected in Device Manager.
When the faulty one is installed in the system, whether by itself or in SLI with the working one, I get this error upon launching any Glide game:
When I try to go into the Desktop properties and click the Voodoo tab, I get this error:
If I remove the faulty one, the other one works fine.
I have tried different motherboards, reinstalled Win98, tried the reference 3.02 drivers and FastVoodoo 4.6 drivers, swapped PCI slots, swapped primary video cards...
I've inspected the card and as far as I can see there are no damaged components, the legs on the chips all appear to be straight and not shorted. I've cleaned the PCI contacts and blown dust off the card with compressed air.
Any other ideas or is the card basically rubbish?
Reply 1 of 13, by SSTV2
Try to disable texturing and see if glide apps start.
Reply 2 of 13, by Tronix
Some quick and dyrty tricks to diagnose your Voodoo2:
First of all, you need clean system with MS-DOS. Pentium 1 or 2 class machine is ideal. Pentium III, 4 and later PC is a bad choice for diagnoses purpose. Do not use any type of overclocking your system, run it with default CPU, Memory and BUS clocks. PCI = 33 MHz.
Secondly, you need download 3dfx Glide2 SDK for DOS/Win32 V2.43 and unpack gwebvgr3.exe. Then change dir to /Glide/Diags/DOS and find diagnose utility MOJO.EXE . Run it with clean MS-DOS enviropment and analyze results.
And, thirdly: glide use some enviropment settings to configure and logging itself. You can try add some string to your AUTOEXEC.BAT for deeper logging whats going on with your Voodoo2:
set SST_INITDEBUG=1
set SSTV2_INITDEBUG=1
set SST_INITDEBUG_FILE=c:\sst1_3dfx.log
set SSTV2_INITDEBUG_FILE=c:\sst2_3dfx.log
set SST_DEBUGDAC=1
set SSTV2_DEBUGDAC=1
Run MOJO.EXE again and then analyze files sst1_3dfx.log and sst2_3dfx.log on your hard disk. If MOJO.EXE halting system, and sst1_3dfx.log and sst2_3dfx.log have zero size when reboot, you can redirect logging output to screen (or RS-232 or printer port):
set SST_INITDEBUG_FILE=CON
set SSTV2_INITDEBUG_FILE=CON
https://github.com/Tronix286/
Reply 3 of 13, by DonutKing
Many thanks for the response, I ran the mojo.exe utility and get this output:
Below is the log file:
sst1Init Routines: InitCode $Revision: 8 $
sst1InitMapBoard(): BoardsInSystem = 1
sst1InitMapBoard(): vAddr:0xde000000 pAddr:0xde000008 Dev:0xd Board:0
sst1InitRegisters(): Setting TREX-to-FBI FIFO THRESHOLD to 0x8...
sst1InitRegisters(): Setting PRELIM FT-CLK delay to 0x8...
sst1InitDacDetect(): Entered...
sst1InitDacDetectICS(): Entered...
dacWr(0x7,0xb)
dacRd(0x5,0x79)
dacRd(0x5,0x2e)
dacWr(0x7,0x1)
dacRd(0x5,0x55)
dacRd(0x5,0x49)
dacWr(0x7,0x7)
dacRd(0x5,0x71)
dacRd(0x5,0x29)
sst1InitDacDetectICS(): Exiting...
sst1InitRegisters(): Storing TREX0INIT0=0x5441
sst1InitRegisters(): Storing TREX0INIT1=0xf420
sst1InitRegisters(): Storing TREX1INIT0=0x5441
sst1InitRegisters(): Storing TREX1INIT1=0xf420
sst1InitRegisters(): Storing TREX2INIT0=0x5441
sst1InitRegisters(): Storing TREX2INIT1=0xf420
sst1InitSetGrxClk(): Entered...
dacWr(0x7,0xe)
dacRd(0x5,0x37)
dacWr(0x4,0xa)
dacWr(0x5,0x7b)
dacWr(0x5,0x6c)
dacWr(0x4,0xe)
dacWr(0x5,0x27)
sst1InitSetGrxClk(): Resetting TMUs after clock change...
sst1InitResetTmus(): Could not reset TMUs...
However I put in my working Voodoo 2 and seem to get the same output on screen and in the log file?
Reply 4 of 13, by DonutKing
I put both cards in and now I get a different result:
sst1InitMapBoard(): BoardsInSystem = 2
sst1InitMapBoard(): vAddr:0xdf000000 pAddr:0xdf000008 Dev:0x11 Board:1
dacWr(0x7,0xb)
dacRd(0x5,0x79)
dacRd(0x5,0x2e)
dacWr(0x7,0x1)
dacRd(0x5,0x55)
dacRd(0x5,0x49)
dacWr(0x7,0x7)
dacRd(0x5,0x71)
dacRd(0x5,0x29)
dacWr(0x7,0xe)
dacRd(0x5,0x0)
dacWr(0x4,0xa)
dacWr(0x5,0x7b)
dacWr(0x5,0x6c)
dacWr(0x4,0xe)
dacWr(0x5,0x0)
sst1InitRegisters(): Setting up FAST DRAM Configuration
sst1DeviceInfo: Board ID: Obsidian GE
sst1DeviceInfo: FbiConfig:0x2, TmuConfig:0x8d1
sst1DeviceInfo: FBI Revision:2, TMU Revison:1, Num TMUs:2
sst1DeviceInfo: FBI Memory:4, TMU[0] Memory:4, TMU[1] Memory:4
sst1DeviceInfo: Dac Type: ICS ICS5342
sst1DeviceInfo: SliDetect:0
sst1InitRegisters(): LFB Writes go through memory FIFO...
sst1InitRegisters(): TEXTURE Writes go through memory FIFO...
sst1InitRegisters(): exiting with status 1...
dacWr(0x7,0xb)
dacRd(0x5,0x79)
dacRd(0x5,0x2e)
dacWr(0x7,0x1)
dacRd(0x5,0x55)
dacRd(0x5,0x49)
dacWr(0x7,0x7)
dacRd(0x5,0x71)
dacRd(0x5,0x29)
Show last 32 lines
dacWr(0x7,0xe)
dacRd(0x5,0x0)
dacWr(0x4,0xa)
dacWr(0x5,0x7b)
dacWr(0x5,0x6c)
dacWr(0x4,0xe)
dacWr(0x5,0x0)
ERROR: non-unique r/b_sum=0xf80
sst1InitFillDeviceInfo(): Retry #1 for chip GetInfo()...
sst1InitFillDeviceInfo(): Retry #2 for chip GetInfo()...
sst1InitFillDeviceInfo(): Retry #3 for chip GetInfo()...
sst1InitFillDeviceInfo(): Retry #4 for chip GetInfo()...
sst1InitRegisters(): ERROR filling DeviceInfo...
sst1InitShutdown(): Shutting down SST-1 #0...
dacWr(0x7,0xe)
dacRd(0x5,0x0)
dacWr(0x4,0xa)
dacWr(0x5,0x41)
dacWr(0x5,0x62)
dacWr(0x4,0xe)
dacWr(0x5,0x0)
sst1InitShutdown(): Returning with status 1...
This section is of note:
Could it be a faulty DRAM chip?
Reply 5 of 13, by bjwil1991
Did the same diagnostics as well and no errors in the log files.
SST1_3DF.log - MS-DOS mode (cleaned up the autoexec.bat file)
SST1_3DFX.log - Windows 9X
VooDoo2.txt - made using this command: MOJO > VooDoo2.txt in MS-DOS mode
The attachment VooDoo2 Logs.zip is no longer available
Reply 6 of 13, by lakreev
Donut King, i have similar issue (same errors). Did you solve It?
Reply 7 of 13, by Joosemachine
I'd also love to know if anyone has had any success resolving this particular "0xdead" error on a voodoo2..
Reply 8 of 13, by RadiTwo
I have a basically pristine Creative Voodoo 2 CT6670.
Looks like it´s never been used.
It has EXACTLY the same error log with mojo as Donut King back in 2019 with his card.
FBI Memory shows 0 MB and TMU PowerOn Sense is 0xdead.
Has anybody an idea what causes this?
Reply 9 of 13, by drosse1meyer
RadiTwo wrote on 2023-07-26, 16:03:
I have a basically pristine Creative Voodoo 2 CT6670. Looks like it´s never been used. It has EXACTLY the same error log with mo […]
I would start with checking for missing caps/resistors, disconnected/shorted pins, verify the chip(s) is getting voltage, tone out traces, etc.
Reply 10 of 13, by bloodem
This may not necessarily be the case for your particular card, but I've seen those exact Mojo errors when trying Voodoo 2 cards - which are known working - on specific motherboards with certain VIA chipsets. Last time I saw this problem was on a VIA KT266A motherboard. I tested three different fully working Voodoo 2 cards (Diamond, Gainward, Creative) and Mojo reported the same problems for all of them. Furthermore, all three cards were completely unusable in Win98SE (display out of range or Windows freezing during boot after installing the Voodoo 2 drivers, etc).
So, my suggestion is to always try the card on multiple boards. Personally, my go-to platform for testing Voodoo 2 cards (and making sure that they actually work) is the 440BX. You can't go wrong with it.
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 11 of 13, by chaoscontrol
Wasn't this on the Bits und Bolts youtube channel some time ago? I think it was the TMU solder detaching ever so slightly in the corners of the chips or something.
Reply 12 of 13, by BitsUndBolts
chaoscontrol wrote on 2023-08-26, 21:10:
My card was a Diamond Monster 3D (Voodoo 1). In my case, the issue was a cracked resistor on the back of the card. I would check all solder joints on the 3Dfx chips and look for cracked SMDs.
Reply 13 of 13, by Thermalwrong
For diagnostics output from the Voodoo 1 / 2 cards, the mojo.exe program has several break points that will give results like you're seeing if there are faults that register before the application reads out the FBI memory and TMU status. Resulting in the FBI having 0MB memory and 57005 TMUs 😀
To see what those are, you need to set up the logging environment variable to get an SST.log / SST2.log file in the same directory as mojo is in.
In my case the FBI was working so drivers could be installed, but it could not communicate with the DAC and therefore mojo.exe faulted out before FBI / TMU status was read. I've written out my experience with this error here: Re: What retro activity did you get up to today?
