First post, by JointCh1L
Hi Guys,
Recently i got a Geforce 2 GTS.
When i tried to install the Forceware drivers from Nvidia the computer doesn't reconise the card as a Direct3D card.
I can play OpenGL games like Quake 2 en 3 but its stuggling with Direct3D.
I was thinking, can it be that i need the Original Asus Drivers for this instead of the latest Forceware drivers ?
And does anyone has original Asus Drivers for Windows 98se ?
My setup.
Intel Pentium III 1000mhz
Asus CUSL2-C
Asus Geforce 2 GTS
512 MB Ram 133mhz
Create SoundBlaster Live 5.1
Windows 98se
Reply 2 of 13, by JointCh1L
Yeh I used the 71.84 drivers, 30.82 and the newest 81.98.
I found an original driver disk for the 7100 series that also contains the drivers for the V7700.
When I installed that one, everything was working fine.
Games don't crash, 3DMark runs normally. ( was crashing everytime when i wanted to start the benchmark ).
Think ill just stick to the Asus drivers than instead of the nvidia drivers.
Reply 4 of 13, by Jasin Natael
First IT job that I ever had, my boss always gave me a hard time for using "generic" graphics card drivers.
He ALWAYS insisted on using the drivers that came bundled with the card, Sapphire or Asus or what have you.
This would have been around 2001-2002, we built a lot of systems ground up back then and I always tended to download the most recent version from chip manufacturer website,
ie; ATi, or Nvidia usually.
Always ticked him off, 🤣.
That doesn't help at all but that's what this post reminded me of.
AOpen AP53 AMD K6/2 - 233MHZ - 64MB RAM 20GB WD HDD Win98SE
Compaq Presario 5152 AMD K6-III+ 550MHZ 512MB RAM ATi Radeon 9250SE 256MB PCI Aureal Vortex 2
Asus A7V-VE AMD Athlon T-Bird 1.20GHZ 512MB RAM ATi Radeon 7500 DDR 64MB Vortex 2 32GB KingSpec SSD
Reply 5 of 13, by Baoran
DirectX version has usually been the main reasons for direct3d not working when installing new drivers for me too. Install at least directx 7.0a and if that doesn't work try directx 8.1 too.
Reply 7 of 13, by Lord_Xearo
Hello Guys,
i think i'm in the same situation. I got my hands on a Geforce 2 GTS (ASUS V-7700) and i cant seem to find any driver that is working out of the box with Windows 98 SE.
is someone here willing to share his working driver / installation disc?
Thanks in advance.
Regards, Xearo
Reply 10 of 13, by leileilol
Generally Geforce2s break after Forceware 61.76. Any "supported" driver after that will break stuff as it feels like Nvidia didn't test them on Win9x at that point.
by the way, DOSBox is not for running Windows 9x
Reply 11 of 13, by elianda
So the ASUS drivers for the V7700 offered here https://www.asus.com/supportonly/V7700%20Seri … lpDesk_download
also show the problem?
Youtube Channel
Reply 12 of 13, by Lord_Xearo
Right, if i search for a driver in this folder it will not find a compatible driver.
if i run the setup file it says something like success (after 2 seconds) and will restart my computer.
Well, at least the driver auron posted did work. But im curious why so many drivers i tryd couldn't find my hardware. i also tryd older versions.
Direct X 9 is installed.....on some other PCs i noticed driver installation issues when directx isnt installed.
Reply 13 of 13, by candle_86
I'm running mine just fine with forceware 30
Phenom II X4 840T @ 4ghz - ASUS M3N72D-SLI - GTX 560 Ti- 4GB DDR2 1066 - 1TB HDD - Windows XP
Pentium 4 3.4C - MSI 865PE NEO2 - x850 XT PE - 2GB DDR 400 - 500GB HDD - Windows XP
Athlon 700 - COMPAQ Board - ASUS Geforce 256SDR - 120GB HDD - Windows 98SE
