Slow AVI with DX4-100 in Windows 3.11
Discussion about old graphics cards, monitors and video related things.
Postby Chaniyth » 2019-4-12 @ 19:20
Greetings all,
Build: ASUS PVI-486SP3 3.06 BIOS, Intel DX4-100Mhz 486 CPU, 16MB RAM, Paradise Bahamas 64 [S3 Trio64] VLB video card, SBPro2, OPTi MAD16 Pro [used only for General MIDI support], Sony 8x CD-ROM Drive [NOS], Sony 1.44mb Floppy Drive, Microsoft Serial Mouse, DOS 6.22, Windows 3.11 WFW
Symptoms: Certain AVI files such as the goodtimes.avi from the Windows 95 CD, or from games such as Age of Sail are horribly slow; around 1fps. Tried multiple CD drives and they all exhibit slowness during AVI playback. The slowness is in sync with the CD drive reading the AVI file. Other AVI driven apps such as Encarta '95 do not exhibit this slowness. I have all the proper Windows 3.x drivers setup for my devices, I also have Video for Windows 1.1E installed.
It could just be an unsupported codec for those AVI files but any helpful information or solutions for this is requested. Thanks in advance. :cool:
All the world will be your enemy, Prince with a Thousand Enemies, and when they catch you, they will kill you... but first they must catch you. :D
User avatar
Chaniyth
Re: Slow AVI with DX4-100 in Windows 3.11
Postby cyclone3d » 2019-4-12 @ 19:37
What happens if you set up a Smartdrive cache for the CD-ROM drive?
What PIO mode is the IDE controller set to in the BIOS? What does Windows say it is running at in the device manager?
Is the IDE controller sharing an IRQ with the video card or sound card?
It sound to me more like a data transfer issue than an AVI specific issue from they way you are describing it.
User avatar
cyclone3d
Postby Jo22 » 2019-4-12 @ 20:19
Chaniyth wrote: I also have Video for Windows 1.1E installed.
Please also check if it's the right version and uptodate (Intel Indeo codecs 3.2 and 4.1 were optional)-
Some VFWs were faster than others (supported DCI ?) if my memory serves me well.
Speaking of the S3 Trio, you also can try the ELSA drivers. They used to be fine, afaik.
See http://win31.de/esoft.htm
Edit: Oh, and please never load CD-ROM device drivers like VIDE-CDD "high", if it isn't necessary.
It just causes trouble often. Better use an alternate driver that's small and leave it in conventional memory.
Edit: Found it! It was Elsa's VfW 1.1e with Offscreen support. -> http://stephan.win31.de/vfw_elsa.zip
User avatar
Jo22
Postby Chaniyth » 2019-4-12 @ 22:29
@cyclone3d SmartDrv is enabled for CD however, with or without though doesn't change anything regarding this matter. IDE modes are in "AUTO", there are no IRQ conflicts.
@Jo22 VFW 1.1E is what I use it's the final release for Windows 3.x. Intel Indeo codecs installed are 2.1/RAW and 3.2 Trying different drivers didn't change anything.
The goodtimes.avi and other AVI's on the Windows 95 CD are in the Cinepak format and the Age of Sail opening cinematic AVI is in the Microsoft Video 1 (CRAM) format. I know for sure the Cinepak codec is installed (version 1.6.0.73), not sure about CRAM but I do have a "Microsoft Video 1 Compressor" listed in the Drivers section of the Windows 3.11 Control Panel, i'm not sure if that is CRAM or not.
User avatar
Chaniyth
Postby mrau » 2019-4-13 @ 00:34
just check if the files copy to the disk or somewhere else with expected speed; You might lso check if the movies copy slower when they play slower - just to check if the cd is well readable in that spot
mrau
Postby Chaniyth » 2019-4-13 @ 01:34
Ok. so some progress has been made. For the goodtimes.avi and other AVI's on the Windows 95 CD it's a CPU speed issue... the CPU needs to run slower [I temporarily disabled the DX4-100's cache] and the videos played fine, so i'm assuming it's either the Cinepak codec at fault or the Windows 3.11 media player at fault. The opening cinematic for Age of Sail however is still sloooowwwww!
User avatar
Chaniyth
Postby Jo22 » 2019-4-13 @ 13:26
Hm. Not sure what it is then. If speed is an issue, did you try to enable/disable FastDisk driver (32-Bit disk access) ?
It's not necessary, normally, but affects overall Windows performance in so far, as it can work in tandem with Windows 3.11's HDD cache (32-Bit file access)
and allows Windows to entirely stay in 32-Bit Protected Mode (if both are enabled), which in turn affects the CPU caches.
I know it's a far strech, but that's all that comes to mind right now (except that it's a video driver issue; i.e., lack of scaling/colour transformation).
See https://en.wikipedia.org/wiki/32-bit_disk_access
(Btw, Microhouse Windows 32Bit Hard Disk driver for drives larger than 540M -> http://win31.de/edrivers.htm)
User avatar
Jo22
Return to Video
Who is online
Users browsing this forum: No registered users and 2 guests
