First post, by stalk3r
Is this CRT any good? There is one for cheap, and I am looking for a decent CRT monitor for the DOS machine.
Reply 1 of 3, by Tiido
It probably is pretty decent as long as it hasn't seen tremendous amount of use as most monitors have. Can you see it in person ? If yes, start it and look at a greyscale gradient. If the darker end is very dark but improves in 10 or so mintues the tube has een plenty of use but will serve well for a while longer but if it is getting tinting then stay away, that tube is worn out and reached end of life.
