First post, by Intel486dx33
I would like to here of some recommendations for the best choice video card for an AMD 5x86-133-P75 overclocked to 160mhz. Currently I am using the Number9 video card with S3 vision 968 chip but if I can use something better what can it be ?
Motherboard - PCChips 918i socket-3 with ALI chipset
I have 3 PCI slots and 4 ISA slots.
300watt PSU.
64mb. EDO Ram 60ns
256kb motherboard cache
Win98b.
CF card 8gb Sandisk extreme.
PCI Cards I have available:
S3
Trident
Matrox Millennium
Matrox G100
Riva TNT
Voodoo-3 3000
ATI Rage 128
ATI
Diamond
Nvidia
Number9
Reply 2 of 11, by Intel486dx33
STX wrote:
Having too many good options is a good problem to have. Personally, I'd try the Voodoo3 if I were you.
Yeah, but is there any advantage to having a Voodoo-3 PCI on a 5x86 CPU ?
Are the Voodoo drivers supported on a 5x86 ?
Reply 3 of 11, by STX
The Voodoo3 offers a combination of very good game compatibility and very good image quality.
According to the Voodoo3 2000 & 3000 FAQs, a Voodoo3 PCI requires at least a Pentium 90. The performance of your overclocked Am5x86 is roughly equal to that of a Pentium 90, so you'd be OK speed-wise. However, the Am5x86 only implements one of the instructions that were introduced with the Pentium architecture, CPUID, so the Am5x86's older instruction set might be a problem. The Am5x86 is not supported specifically, but that doesn't necessarily mean that it won't work. If I were you, I'd just back up my hard drive, install the Voodoo3 and see if it works. I'd choose V1.01.02 drivers because they're the last drivers with "Intel, AMD, Cyrix, or compatible processor" as requirements; later drivers' requirements list specific CPUs, and the Am5x86 isn't one of them.
Reply 4 of 11, by elianda
I would stay with the S3 Vision968. It has very good VESA support and mode compatibility.
Youtube Channel
Reply 5 of 11, by matze79
i would opt for the Matrox Card.
Or a Riva128 which is very good for 2D VESA compatiblity.
Reply 6 of 11, by chinny22
Problem is even a 5x86 struggles at 3D so really you'll be focusing on 2D
You could try out some of those early 3d API's that didn't kick off
S3 Virge S3D is the most interesting as it has the most games, I have this in my 5x86, the games run but struggle a bit.
Reply 8 of 11, by keropi
S3 gets my vote too, you need a compatible and fast 2d vga - 3d is wasted on such machine
Reply 10 of 11, by dirkmirk
Im using a Matrox Mystique 4mb in my overclocked 5x86-160 machine, using the LCD monitor the image is great! Most S3 Virge cards display too bright for some reason but the S3 TRIO I have lying around has no problems.
Ive fiddled with 3D cards on the 486 systems but its not really worth it, I personally think keep it somewhat period correct and go for a 2D card.
