First post, by RoyBatty
- Oldbie
Here's a quick and easy solution to replacing the fans on any 3DFX card which has one.
As a replacement fan I found that a Noctua NF-A4x10 FLX is an ideal replacement fan that runs off 12v with 3 pin molex connectors that are easily adapted to a 12v 4 pin molex. They are the right size, have good airflow and are quiet.
You'll need some slightly longer replacement screws to mount them on the heat sinks the same as the originals. I found that a #5-40 x 1/2" machine screw was a perfect fit. The thread doesn't matter as much as the correct diameter and length. I could only find flat head ones rather than phillips head or hex, but that hardly matters.
Pic of Voodoo 5500 with replaced fans.
