Matrox driver performance
Discussion about old graphics cards, monitors and video related things.
Postby cxm717 » 2019-5-15 @ 05:25
Just like my other threads about driver performance https://www.vogons.org/viewtopic.php?f=63&t=66563, https://www.vogons.org/viewtopic.php?f=63&t=66296 and https://www.vogons.org/viewtopic.php?f=63&t=65409
The card I used is a Matrox G400max (150/200). I used the same test setup: P3/800EB, intel OR840 board, 512MB 800MHz RDRAM and a Creative Soundblaster live.
Here are the benchmark results:
I am going to do a comparison of just the different TurboGLs but I'm going to do it on a 440BX board. The reason for this is the OR840 has no AGP aperture setting and it defaults to a size of 64MB. Matrox recommended an aperture setting of 256MB, lower than this and you may get texture corruption or crashes. I did test the games that worked fine with the TurboGL and an AGP aperture size of 64MB.
User avatar
cxm717
Re: Matrox driver performance
Postby appiah4 » 2019-5-15 @ 13:12
You, sir, are godsend.
A500:+512K|ACA500+|C1084S
i386:Am386SX-25|4M|TVGA9000B|ES688
i486:U5S-33|8M|GD5428|YMF719|MUNT-Pi
i586:P133|32M|T64+/MX2|V1|CT3980/32M|SD-35
i686:K6-2/400|64M|V2/SLI|CT4500/32M
S370:P3-1200|384M|GF4Ti4200|MX300
S754:A3700+|2G|X1950PRO|SB0350
User avatar
appiah4
Postby dottoss » 2019-5-15 @ 13:32
Thank you for this! I was just doing a Matrox build and was wondering which driver to use. It seems the latest are overall good enough :)
User avatar
dottoss
Postby Tiido » 2019-5-15 @ 22:30
It is interesting to see that here we see a general trend of higher performance with newer drivers but with other manufacturers comparisons I have seen show mostly the opposite lol.
User avatar
Tiido
Postby swaaye » 2019-5-16 @ 19:18
I think the 256MB AGP Aperture recommendation is related to BIOS bugs with some motherboards. Digging through the MURC forum shows some people had major problems with the cards if AGP aperture wasn't at 256MB.
Look at TurboGL go. :) It's supposedly quite nice for K6-2/3 too. I think G400 is troublesome on those motherboards though. The usual AGP quirks.
swaaye
Moderator
Postby appiah4 » 2019-5-16 @ 20:29
swaaye wrote:I think the 256MB AGP Aperture recommendation is related to BIOS bugs with some motherboards. Digging through the MURC forum shows some people had major problems with the cards if AGP aperture wasn't at 256MB.
Can TurboGL be used with a G450? Support came with 6.x drivers..
User avatar
appiah4
Postby bofh.fromhell » 2019-5-17 @ 22:25
Fantastic job !
I had a feeling that Matrox improve over the driver revisions.
But its nice to know =)
The Matrox cards definitly have their limitations.
But I really like them as retro cards !
User avatar
bofh.fromhell
Postby cxm717 » 2019-6-18 @ 18:17
Here are the TurboGL results on the 440BX chipset:
I included the 840 with driver 555/TGL 1.3 in the graph. I did test all of the games on the BX (D3D and OGL ICD) but I haven't made any graphs for it yet. The G400 is almost always faster on the BX than the 840, mostly just around 5% though. The reason there are no TGL results for Q2 engine games using the TGL with the 6.xx drivers is because you get some pretty bad texture corruption with dynamic lighting enabled.
User avatar
cxm717
Return to Video
Who is online
Users browsing this forum: _UV_ and 1 guest
