First post, by xjas
Yes, I know... 😜
I haven't been able to get this to work, in spite of "internet scuttlebutt" and instructions on here saying it should be possible. I tried both v1.0 of the demo from Phil's website, and a much later version from a Parhelia CD I had with the same result.
I also edited 'tdrg_v2.ini' to set the resolution manually and set "frequency=0", which someone in an old forum thread elsewhere said was needed for Win98 - this fixed a "cannot initialize video mode" error, at least. I also turned high res textures off since I only have a 64MB card.
At the moment the screen goes black for a second, and it looks like it's going to start, but then spits back to the desktop with this error:
1.7 KiB
Here's my 3D-Analyzer settings:
50.03 KiB
My machine is an Athlon XP on a VIA KM266 chipset, GF3 Ti200, running the 45.23 driver package on Win98SE with DX9.0c installed.
Any suggestions on getting this to run?
Reply 1 of 5, by Stiletto
Maybe try setting your VendorID and DeviceID to a Matrox Parhelia card? Not sure if that's necessary, but if it's triggering on a card identification issue...
do the Fandango!" - Queen
Stiletto
Reply 2 of 5, by xjas
^^ I thought that's what I did... Should be V=4139 / D=1319 according to the internet, right?
Reply 3 of 5, by Fusion
https://arstechnica.com/civis/viewtopic.php?f=6&t=706469
Everyone in this thread didn't seem to have an issue. OP didn't mention changing VendorID/DeviceID either.
Did you run the .bat file that 3Danalyse creates for you in the demo directory?
WIP Retro Files
P3 800 | 512MB PC100| PCI V3 3000 16MB @ 195/195 | CT4780 SB Live! Value| WinME
P3 450 | 128MB PC100| AGP TNT2 Pro 32MB | CT4170 SB16 | MS-DOS 7.10
A64 2.4 | 2GB DDR1 | PCI-E Radeon X800XT @ 575/575 | Win2K
Reply 4 of 5, by Stiletto
D'oh, didn't catch that...
Stiletto
Reply 5 of 5, by xjas
Yep, saw that thread... somebody on there even claims to have it working on a GF3 Ti200, so not sure what's wrong on my system. I get the same result running the batch file as running it from within 3D-analyze manually.
ON THE OTHER HAND, I just figured out it runs beautifully on my Win7 machine with a GTX 750Ti, so I dunno? Didn't even need to set the Device/VendorID. Maybe the 3D-Analyze fix just doesn't work in Win98.
To be honest, this demo could have been released last year for how good it looks.
