Drivers for VLB card S3 p86c805 wont work
Discussion about old graphics cards, monitors and video related things.
Postby northdale » 2019-6-12 @ 16:43
I have almost this card http://www.vgamuseum.info/index.php/new ... -s3-86c805
But it says p in front "p86c805" and no I at the end.
I have tried to install drivers for it (win 3.11) but non of the drivers seam to work. Windows restarts into dos saying could not start the driver.
I have tried a few drivers as you can see here.
youtube.com/uncleawesome
northdale
Re: Drivers for VLB card S3 p86c805 wont work
Postby blurks » 2019-6-12 @ 20:04
What is the source of these drivers? Have you tried the files from metropoli BBS?
> http://files.mpoli.fi/hardware/DISPLAY/S3/
I'm not sure whether 805 and 805i chipsets share the same driver files ("i" = memory interleaving) but most likely yes.
User avatar
blurks
Postby northdale » 2019-6-12 @ 22:59
Hi. Yes I tried these drivers.
And drivers from here: viewtopic.php?t=28133
and here http://www.retrocomputing.org/cgi-bin/s ... d=retroorg
I just installed another vlb card that works, but I would prefer the other one.
northdale
Postby elianda » 2019-6-13 @ 08:06
If the card has a jumper to enable INTerrupt, then make sure that it is set.
Youtube Channel
User avatar
elianda
Postby northdale » 2019-6-13 @ 21:47
Thanks I will check it out
northdale
Return to Video
Who is online
Users browsing this forum: No registered users and 2 guests
