Difference of qualities by manufacturer (VOODOO 1 and S3)
Discussion about old graphics cards, monitors and video related things.
Postby Señor Ventura » 2019-7-09 @ 22:59
Hello
Between this two cards there are differences about its DAC, and the memories, but Should i must have in consideration any difference of possible qualities?.
Which you choose?
Thank you.
Señor Ventura
Re: Difference of qualities by manufacturer (VOODOO 1)
Postby mothergoose729 » 2019-7-09 @ 23:13
This thread might be of interest to you:
viewtopic.php?f=46&t=41369
Diamond is really the reference AIB, but I don't know enough about them to say which one is of better quality. I guess you could plug both in and see which gives you the most clean picture.
mothergoose729
Postby Señor Ventura » 2019-7-09 @ 23:22
mothergoose729 wrote:This thread might be of interest to you:
I meant about difference about qualities in terms of quality of components (durability, etc).
I will try reading that thread, thank you :)
Señor Ventura
Postby kjliew » 2019-7-10 @ 00:05
I would typically say go for Diamond, but the 1st card really caught my attention. It has TVP3409-170CFN DAC, which was originally from Texas Instrument. All Voodoo1 that I had come across all used ICS GENDAC. This one is really special. Ti DACs are famous for superb analog quality, Matrox used the higher end TVP3026-220/250 in the professional Millennium/Millennium II graphic cards in the 90's, which were always the best analog output back then.
Though I am not sure if TVP3409 would be in the same league as TVP3026, with Ti reputation I think it's worth to take a look.
kjliew
Postby maxtherabbit » 2019-7-10 @ 01:48
I agree, I would go for the TI DAC definitely
User avatar
maxtherabbit
Postby Señor Ventura » 2019-7-10 @ 02:14
kjliew wrote:I would typically say go for Diamond, but the 1st card really caught my attention. It has TVP3409-170CFN DAC, which was originally from Texas Instrument. All Voodoo1 that I had come across all used ICS GENDAC. This one is really special. Ti DACs are famous for superb analog quality, Matrox used the higher end TVP3026-220/250 in the professional Millennium/Millennium II graphic cards in the 90's, which were always the best analog output back then.
Ok, it's done, i already bought the one with the TI DAC.
I almost done with my P200 upgrades. Thank you to all :)
Now about 2D cards:
The first one has 2MB in 8 memories, and the second one has 2MB in 4 memories... i don't know what is better.
Señor Ventura
Return to Video
Who is online
Users browsing this forum: No registered users and 2 guests
