Voodoo3 + Via 133 chipset freeze
Discussion about old graphics cards, monitors and video related things.
Postby kolderman » 2019-7-12 @ 10:29
I am building a mATX Win98 system using a mobo based on Via Apollo Pro 133 (VT82C693A) and a Voodoo3 3000 AGP. Everything seems to install up to the point of the Voodoo drivers, after which when I boot up and open windows explorer, the system freezes.
Via 4in1 435v
Voodoo3 driver 1.07 WHQL
Win98 SE
I tried with/without the AGP driver from the 4in1 pack.
Bad mobo/card or both? Anything else to try?
kolderman
Re: Voodoo3 + Via 133 chipset freeze
Postby RoyBatty » 2019-7-12 @ 18:16
Try the last set of drivers, 4.42, also try setting the AGP to 1X and see if it boots.
User avatar
RoyBatty
Postby kolderman » 2019-7-12 @ 21:51
So I tried everything, the only consistent result was when the 3dfx drivers are installed, the system hangs.
Then I tried a PCI voodoo3, a AGP voodoo banshee and than another AGP voodoo3, and they all worked!
So clearly it was the card, which is unfortunate as it was a NIB/NOS model with a stock fan on the heatsink (which I have never seen before on a v3). It did not show any of the common signs of a faulty card though (banding, artifacts), so I am hoping that just this card did not get along well with this particular motherboard. Now I need to find a way to cool this other v3 in a case I was hoping to be near silent...
kolderman
Postby aaronkatrini » 2019-7-13 @ 08:39
Is that a V3 from EvilKing? Please share some photos! Thanks
aaronkatrini
Postby kolderman » 2019-7-13 @ 10:20
As a matter of fact it is!
kolderman
Postby aaronkatrini » 2019-7-13 @ 15:04
Nice card, there was a guy who tried using a heat gun on an identical card, lucky for him it worked great. Can't you test the card on another system?
aaronkatrini
Postby Bige4u » 2019-7-13 @ 15:57
Now thats what 3DFX should have done with all their Voodoo3 cards from the git go.... adding a fan to a heatsink that got blistering hot while in use, gaming or not, the Voodoo4/5 cards had fans.
Btw.... use v4.43 4in1 driver for the via apollo pro 133 chipsets, i happen to have an Aopen AX64 motherboard running an actual 1ghz/133 slot 1 processor, not sloket with that same chipset, and the driver i mentioned work great.
Pentium3 1400s / Asus Tusl2-c / Crucial 256mb pc133 cl2 / WD 20gb 7200rpm / GeForce3 Ti500 64mb / SB Live! 5.1 / 16x dvdrom / 3.5'' Floppy / Enermax 420w 20pin / Win98se
User avatar
Bige4u
Postby kolderman » 2019-7-13 @ 21:53
aaronkatrini wrote:Nice card, there was a guy who tried using a heat gun on an identical card, lucky for him it worked great. Can't you test the card on another system?
I will when I get a chance, I am currently focused on building out this current system. I have a good feeling though as it was a system crash after installing drivers on a Via chipset (not screen corruption)...my experience with the latter leads me to suspect it's the chipset not the VGA.
kolderman
Return to Video
Who is online
Users browsing this forum: No registered users and 3 guests
