First post, by aaronkatrini
- Member
I have a partially broken v3 and wanted to check if any broken capacitor were broken under the Heatsink, and with this easy trick I could get it off in less than 10 seconds. You just need dental floss and place it between the chip and heatsink.
https://youtu.be/W7oL3sfztUU
No glue / thermal compound was found under at the chip, it was all in the heatsink. Now I need to find a way to clean it without scratching.
