First post, by respect2759
Hi guys, I need some help. I have a Radeon X1600Pro 512Mb AGP card which I want to use in an XP gaming machine. Card makes artifacts, I got it in this condition. I cant afford now to buy another one and I want to upgrade from 128Mb. I removed the heatsink, cleaned the card, tested some traces and I found a dead capacitor. I tested all the caps - loaded them with a multimeter with resistence function and tested voltage. Only one is bad. I have recapped some motherboards, but I changed only those barrel type electrolytic capacitors. This one is a vertical chip capacitor and has different markings, I dont understand it. I know on these the marked one is + but there are some numbers and letters on the top. I read everything what I found, tried some capacitor code decoders, but I am not an electrician and I cant figure out the meaning of codes. Yeah, I know now I look stupid but those barrel types are so easy. Capacitance, voltage and temperature. I found some articles which tells the first two digits are the capacitance and the third is a multiplier. The third digit must be 0,1,2,3,4,5 or 6. Mine has this:
67Z
100
6V
It makes sense only when I read it from top like 616 which is 61uF and 70 volts. My question is a bit dumb. This is the right way to read these capacitors? From top? And not from left to right? Thanks for answers, have a nice days
Soyo 019R1 AM386DX 40MHz, 8Mb ram, 512Kb Trident 9000 Graphics
S26361-D756-X Intel i486DX 33MHz, 4Mb ram, 512Kb - 1Mb graphics on board
Reply 2 of 6, by respect2759
derSammler wrote:
First line "67Z" has no meaning (it's a code from the manufacturer). The cap has 100uF and is rated for 6V.
6V? Cant find only 6,3V
Reply 4 of 6, by respect2759
derSammler wrote:
Yes, 6.3V. It's normally written as 6V on most caps.
Thanks, that 6V confused me a bit. Will solder a new one tomorrow and post the result
One more question 😊
W1
47 0C
UD
Another cap on that GPU. Its functional but how to tell the capacitance of this one?
Reply 5 of 6, by EleDip
respect2759 wrote:
W1 47 0C UD […]
W1
47 0C
UD
That code is for a 47uf cap rated for 16V. There's a page here which seems to confirm and explain it a bit more (down the page).
Reply 6 of 6, by respect2759
EleDip wrote:
respect2759 wrote:
W1 47 0C UD […]
W1
47 0C
UD
Thanks, this really helped 😊 The card makes artifacts after repair too 🙁
