First post, by JackH
I have two Cirrus Logic CL-GD5446BV HC-V 1Mb (expanded) PCI cards (one with 60ns rams and other with 70ns rams), both looking fine, both have this same vertical lines problem when using lower resolutions, 256 color mode in Windows ME (I also tested them in my Windows 98 PC without drivers) and in DOS games? When I changed to High Color 16 bit or True Color 24 bit modes in my Windows ME PC, they worked fine? Windows games and DOS games with SVGA resolutions support (like DN3D, 800x600) worked. Monitors were Benq 21,5-24" models G2222HDL and BL2400PU (I changed to 4:3 aspect ratio, no affect). Should I try with CRT monitor or with some other drivers? Any suggestion how to fix this? It has been 10 years since I last time used these cards and do not remeber this issue?
P.S. Windows ME automaticly installed drivers: CIRRUSMM.DRV 4.10.1650 and CIRRUS.VXD 4.10.1633
Here is some example pics: https://drive.google.com/open?id=1iAcnsZdgFFo … ijiW3j-7f3aEhnu
P.S.2 Anyone who has this model series card have you faced this problem? I also have DOS 5.0 PC with Cirrus Logic CL-GD5428 (integrated ISA card) no problems.
Reply 1 of 7, by The Serpent Rider
Vertical lines on which resolutions? Lines usually appear on cheap ISA/VLB video cards paired with LCD monitor when anamorphic resolution is used: 320x200, 640x400 and everything in-between. But 320x240 should be fine though.
Reply 3 of 7, by JackH
320x200 to 640x480 which most DOS games use?
Reply 4 of 7, by keropi
It's not the capacitors this is a known issue with the DACs or the output stage of many older VGAs combined with LCD screens. It can depend on resolution/refresh used or it could be present all the time.
There is no solution yet other than replace the VGA card with another that does not exhibit this behavior.
Reply 5 of 7, by JackH
Thx everyone for the quick advices. I will try with other monitor settings and with CRT. I let know how it went. By the way I read while a ago about some UniVBE / VESA drivers, would they solve this?
Reply 6 of 7, by keropi
no it's not a driver issue at all. it's a resolution/refresh/output-stage combo issue.
Reply 7 of 7, by Windows9566
S3 cards are more LCD friendly than Cirrus cards, both my GD5446 2mb cards and a GD5434 1mb have that same jailbar issue. My S3 Vision864 VLB, Trio32 PCI, Trio64, Trio64v+, and Virge DX don't have that issue.
Monitor - Dell 1704FPVt
Games that i tested - Aces of the Pacific, Commander Keen 5 The Armageddon Machine, Wolfenstein 3D
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
