First post, by Violett'Blossom
I have got this crt yesterday, and the colors are amazing, I want to hook it up on my main pc as a monitor for gaming, however my current card doesn't have D-Sub, So I wanted to ask if it is possible to get full 160Hz out of this adapter.
Any info is greatly appriciated 😊
Retro gaming : Compaq Armada E500
Portable : MacBook Air 2012
Hackingtosh : I5 6500 8GB DDR4 RX480 8GB
Reply 1 of 6, by Tiido
You're only gonna get 160Hz in fairly low resolutions (1024x768 and less), both due to monitor and any converter limitations. Cheap converters pretty much top out at 1920x1080 at 60Hz or other similar spec.
Reply 2 of 6, by Violett'Blossom
Thanks for response, I don't mind playing at lower res 😀 soo Will it work or not ?
Reply 3 of 6, by Doornkaat
Did a previous reply based on misreading your question. Sorry.
Regular convertors will not be able to output VGA @ 160Hz. There may be professional equipment capable of doing so but from the top of my head I don't know any and it's probably expensive as hell. There just isn't really a market for that sort of thing.
Aaand I've been talking out of my ass again.
https://www.aten.com/au/en/products/professio … nverters/vc812/
Has adjustable scaling and an output pixel clock of 165MHz which should be what 1024x786@160Hz needs. Only question is wether the software supports custom output settings.
Reply 4 of 6, by duga3
Generally yes, depends on the adapter though. I have the Sunix DP-3000 adapter which has at least 500MHz pixel clock. 2070SB can do at 4:3@160Hz a max of 1056x792px which needs only about 200MHz though. You would want 500MHz for resolutions like 2784x2088@60Hz.
There is also a built-in service menu on 2070SB which you can use to tweak white balance and pedestal (black) level, see page 33 in the service manual.
98/XP multi-boot system with P55 chipset (build log)
Screenshots
10Hz FM
Reply 5 of 6, by rmay635703
Factory Preset Resolution Modes
2048 x 1536 / 86 Hz
1920 x 1440 / 92 Hz
1856 x 1392 / 95 Hz
1800 x 1440 / 92 Hz
1800 x 1350 / 98 Hz
1600 x 1200 / 109 Hz
1280 x 1024 / 127 Hz
1024 x 768 / 160 Hz
800 x 600 / 160 Hz
640 x 480 / 160 Hz
Reply 6 of 6, by weldum
I think you should try, I have a DVI (Digital) to VGA (Analog) active converter and it only supports 60hz refresh rates and 70hz on modes that require it.
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
