duga3 wrote:Download that moninfo utility I linked above and copy-paste all of the reported "Asset Information" for your monitor (which shou […]
Download that moninfo utility I linked above and copy-paste all of the reported "Asset Information" for your monitor (which should be already pre-selected in "Display IDs" column) here.
It would be great to know the exact error message you get when installing that INF driver setup file.
What exact adapter do you have?
Are you using BNC or regular VGA cable for this? If BNC, try VGA because BNC is not wired for EDID transfer.
I am using Axagon DP to VGA adapter with shielded VGA cable.
When installing inf it told me that They cannot add the inf because it might be for 32bit version only, also the inf that i got from the moninfo Iam unable to use since it's not digitally signed...
Monitor
Model name............... DPro 2070SB
Manufacturer............. Mitsubishi
Plug and Play ID......... MEL4632
Serial number............ 47005512YB-5512
Manufacture date......... 2004, ISO week 28
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 400 x 300 mm (19,7 in)
Power management......... Standby, Suspend, Active off/sleep
Extension blocs.......... 1 (CEA/CTA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,627 - Ry 0,341
Green chromaticity....... Gx 0,292 - Gy 0,605
Blue chromaticity........ Bx 0,149 - By 0,072
White point (default).... Wx 0,283 - Wy 0,297
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-140kHz
Vertical scan range...... 50-160Hz
Video bandwidth.......... 420MHz
CVT standard............. Not supported
GTF standard............. Supported
Preferred timing......... Yes
Native/preferred timing.. 1600x1200p at 85Hz (4:3)
Modeline............... "1600x1200" 229,500 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
720 x 400p at 88Hz - IBM XGA2
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
640 x 480p at 85Hz - VESA STD
800 x 600p at 85Hz - VESA STD
1024 x 768p at 85Hz - VESA STD
1152 x 864p at 75Hz - VESA STD
1280 x 1024p at 85Hz - VESA STD
1600 x 1200p at 75Hz - VESA STD
1920 x 1440p at 85Hz - VESA STD
2048 x 1536p at 85Hz - VESA STD
EIA/CEA/CTA-861 Information
Revision number.......... 3
IT underscan............. Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Not supported
Native formats........... 1
Detailed timing #1....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27,000 720 736 798 858 480 489 495 525 -hsync -vsync
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 2.0.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... No
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 225MHz
CE video identifiers (VICs) - timing/formats supported
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1280 x 720p at 60Hz - HDTV (16:9, 1:1) [Native]
720 x 480p at 60Hz - EDTV (4:3, 8:9)
NB: NTSC refresh rate = (Hz*1000)/1001
CE video capability data
CE scan behavior......... Supports overscan and underscan
IT scan behavior......... Supports overscan and underscan
PT scan behavior......... Not supported
RGB quantization range... Not supported
YCC quantization range... Not supported
Report information
Date generated........... 27.08.2019
Software revision........ 2.91.0.1043
Data source.............. Real-time 0x0011
Operating system......... 10.0.18362.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,34,AC,32,46,88,15,00,00,1C,0E,01,03,80,28,1E,78,EB,9C,68,A0,57,4A,9B,26,
12,48,4C,FF,EF,80,31,59,45,59,61,59,71,4F,81,99,A9,4F,D1,59,E1,59,A6,59,40,30,62,B0,32,40,40,C0,
13,00,8C,29,11,00,00,1E,00,00,00,FD,00,32,A0,1E,8C,2A,00,0A,20,20,20,20,20,20,00,00,00,FC,00,44,
50,72,6F,20,32,30,37,30,53,42,0A,20,00,00,00,FF,00,34,37,30,30,35,35,31,32,59,42,0A,20,20,01,9B,
02,03,1B,61,23,09,07,07,83,01,00,00,67,03,0C,00,20,00,80,2D,43,90,84,02,E2,00,0F,8C,0A,D0,8A,20,
E0,2D,10,10,3E,96,00,A0,5A,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,29
