First post, by Paar
- Member
Few months ago I have bought Voodoo 3 2000 in full working order. Then, few weeks back, I have bought another Voodoo 3, this time model 3000. The latter was not working - the PC booted fine with no problems but I got no picture. Tried to flash BIOS with no luck.
So I tried to desolder the BIOS chip and use one from the V3 2000. I have used a hot air gun set to 300°C. The chips didn't come off easily, I had to blow air on them for about minute or two. Cleaned the cards, swapped the BIOS chip and got beeps in POST that indicate missing video card. So I have soldered the chips back to their original cards and got the same result. The cards don't work anymore.
I have tried the BIOS chips in my flash programmer before soldering them and they both work flawlessly. I have probably heat damaged some other component and that's my question - do you have an idea what could get damaged? There are lots of small SMD caps and resistores and a crystal clock right next to the BIOS chip.
Both cards are original 3DFX versions.
http://www.vgamuseum.info/index.php/cpu/item/ … x-voodoo-3-3000
