First post, by Storm82
I got a cheap defective Creative Voodoo2 8mb recently and I want to try everything to get it working again 😀
First the pass-through does not work somehow. I've already checked the resistor values next to the VGA in and out ports. They seem to be correct
I also checked the card with mojo.exe and everything seems to be detected correctly.
Windows 98SE also detects the card and the fastvoodoo drivers install without issues and the memory is correctly detected in the properties.
Any idea?
Here are some pictures from the card:
