First post, by wacha
Hi guys.
Like many of you on this forum, I have a collection of vintage PC hardware that I like to use and tinker with incessantly. Last year I bought an AGON AOC 1440p 144Hz monitor for my main rig, driven by my two 1080Ti's in SLI. I made sure that it supported not only the lastest standards, but also VGA, so that I could connect my vintage DOS/Win98/WinXp era hardware natively, without the use of adapters or dongles. The monitor has 2 DP, 2 HDMI and a VGA port. So far so good on the VGA side, as long as I stay at or below the maximum 1920x1080 resolution supported by the monitor in that mode.
Before I begin to describe my issue, I would like to say that my target is 1440p 60Hz on any GPU capable of that. The problem is that I have a bunch of cool cards from the 2005 to 2012 era that only have DVI ports. Some of the newer ones have one HDMI or mini-HDMI port but it will get disabled in Quad SLI or 4 Way Crossfire modes. So to solve the problem I bought one of those DVI to HDMI passive cables, and at first glance it seemed to work, but it doesn't. It works at a maximum of 1080p 60Hz, but it will only do 1440p 30Hz after forcing a custom resolution. By default it will show 1080p 60Hz.
I think I've been able to pinpoint the problem: the Single Link DVI 165 Mhz pixel clock limit. I have tested this forcing custom resolutions using Custom Resolution Utility 1.4.2. Anything beyond 165 Mhz Pixel Clock will make the image blurry and text unreadable. The connector is Dual Link, but I've since learned that half of the pins are dummies as HDMI is always Single Link and those extra pins are not connected to anything. The absolute maximum I've been able to achieve is 1440p 41Hz using the LCD-Reduced option. So my question is: can a DVI-D Dual Link output be converted to HDMI or Displayport? I've spent countless hours searching and reading misleading advertising and have only been able to find this: http://www.thruput.co.uk/home/product/videopr … g/GFVTCTLA.html
Sadly, I can't find it in stock anywhere. Do any of you have this same setup? How did you resolve this issue?
Now to the thing that completely baffles me: there is one instance where the cable works with a 1440p 60hz display. This is only possible with one of my GTX 295's. Installing the drivers will autodetect the native resolution of the monitor and automatically show it. No custom resolutions, no tinkering, it just works. I have 3 GTX 295's and the other two will display nothing when presented with this resolution. Mind you, it is the default resolution, so simply installing the drivers on any of those two cards will net you a black screen and a "no signal" message shortly afterwards. To be able to use any of those cards as a display with the adapter I have to install the drivers in the one that works, downgrade to 1080p, shutdown, and finally connect one of the other cards.
There is one other instance where I got this to work though, through forcing a custom resolution with the CVT - Reduced Blank option selected: my two GTX 590's. Nothing works with any of my other cards. Here's a list of the behaviour with different cards, when attempting 1440 60Hz:
-Gigabyte GTX 295 Single PCB: works out of the box, default resolution
-ZOTAC GTX 295 Single PCB: default resolution when installing drivers, but only shows black screen, have to downgrade to 1080p using the Gigabyte one
-Gainward 295 Dual PCB: same as the ZOTAC
-GTX 590's: defaults to 1080p, black screen when forcing 1440p, success with the CVT - Reduced Blank option selected
-HD 7990, 7950 GX2, HD 3870 X2, x1950 XTX, X850 Platinum Edition: defaults to 1080p, blurry image if Pixel Clock greater than 165 Mhz, no success
That's all I've tested for now, which seems enough. This situation leads me to believe that the cable might work, but I sincerely have no clue as to why it only does so in a single model of GTX 295. I've tried numerous driver versions, and it's always the same behaviour.
Thank you for your time. I hope we can resolve this and hopefully learn something in the process.
Reply 1 of 16, by dr_st
wacha wrote on 2020-02-20, 14:54:
That's correct. DVI single-link and HDMI are electrically compatible, but beyond that, they are not.
It will have to be this or something equivalent - an active converter.
It's possible that that particular card has circuitry that knows how to output a high-clock HDMI signal on the single-link DVI connector pins, whereas the others do not. The card detects the monitor's capabilities during the handshake and switches on the fly to the required signal type. It's a similar idea to outputting an HDMI signal via the DisplayPort++ connector or an analog RGB (VGA) on the DVI-A connector. At least that's my guess.
Reply 2 of 16, by wacha
Hi dr_st.
Thank you for your prompt and informative response. Your take on the Gigabyte GTX 295's "misterious" capabilities makes a lot of sense, my best guess would have been a VBIOS version (or witchcraft), but yours is definitely better. It makes me wish some of the other cards would be able to do the same thing though, as it would make matters much easier. If you allow me to request a little more of your time, would you happen to know any vendors or manufacturers that sell those kinds of active adapters? The only things I can find are the reverse converters (DP or HDMI to DVI) and terribly misguiding (or outright lying) ads for passive cables or dongles like the one I have. Amazon is especially ridden with the latter, and they always come up first when googling.
I still find it odd that the other two GTX 295 cards don't default to 1080p when first installing the drivers, but instead try to display 1440p and fail miserably. I mean, if I wasn't lucky enough to have the Gigabyte one, I wouldn't even be able to use those cards at all. None of the other cards I've tested behave that way. They even try to do 1440p, it's blurry and unreadable, but they don't just give up.
Reply 3 of 16, by cyclone3d
Visiontek made a DVI-D (digital only) to DP adapter cable that does 1440p.
https://www.visiontek.com/dvi-to-displayport- … -cable-m-m.html
Looks like you can order it from Amazon:
https://www.amazon.com/VisionTek-Products-Dis … e/dp/B0157RW0J4
Most older cards have DVI-I (digital + analogue) ports.
You may need a go-between such as a KVM switch.. look at the reviews on Amazon.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 16, by imi
DVI-I just has extra pins, you can plug any DVI-D cable into a DVI-I port, but not the other way around.
edit:
I see what you mean by the amazon ratings... that is weird though, there should be no difference between the digital output on a DVI-I and a DVI-D port
maybe they tried using it on cards that don't support 1440p?
there is no such thing as a DVI-I digital signal, a DVI-I port just has additional pins that carry the analogue signal.
Reply 5 of 16, by cyclone3d
imi wrote on 2020-02-20, 18:21:
DVI-I just has extra pins, you can plug any DVI-D cable into a DVI-I port, but not the other way around. […]
edit:
Yeah, I know. Doesn't make a lot of sense to me either.
YMF7x4 Guide
Reply 6 of 16, by dr_st
It's most likely a typo - they either meant to write DVI-A or don't know the differences between DVI-I and DVI-A. In any case, I think their meaning is clear - the adapter can convert a digital signal, not an analog one.
Reply 7 of 16, by wacha
Hi guys.
Thank you for your responses. Weird as it sounds, I don't think it's a typo. I mean, quotinq directly from the amazon seller's FAQ:
Q:the dvi end of this doesn't have the analog video pins present on a dvi-i port, so why wouldn't it work off the digital signal […]
Q:the dvi end of this doesn't have the analog video pins present on a dvi-i port, so why wouldn't it work off the digital signal in a dvi-i port?
A:The wiring is not set to support DVI-I. This unit simply was not manufactured to support it.
R:Then you need to change this misleading part of the description "DVI-I Analog signal is not supported. " which conflates the signal output with the port type.
At minimum, it should read: "Digital signal output from a DVI-I port is not supported. "
To be more unequivocal, change the entire line to read as follows:
"Supports DVI-D ports only. Digital signal output from a DVI-I port is not supported. "
And be sure to fix it on your website (https://www.visiontek.com/dvi-to-displayport- … -cable-m-m.html) too.
If you had done that, or if your support department had responded to the email I sent before I bought this (which even now they still have not done), I wouldn't have to return it now.
And from one of the reviews:
Ironically, in my case it did work just well enough on the *digital* signal from a DVI-I port to make me think there was a software issue: it did allow a 2560x1440 monitor to run at 1080p (from a video card capable of 2560x1600). After an email to Visiontek's tech support went unanswered for several days, resulting in many hours of troubleshooting trying to determine if different video card driver software was needed to get the monitor's native 2560x1440 res. (without any success), I finally got the answer from Visiontek: this cable does not work correctly with DVI-I *digital* signal either.
Which sounds exactly like the problem I'm having with the passive cable. Is there even such a thing as an "active cable"? Don't active converters have a separate cable that draws power from a USB port or directly from the wall? It just looks like the cable I bought from Amazon Basics, but 5 times more expensive. Now that I think of it, I believe I haven't tried my cable on a GPU with a DVI-D connector. I'm going to test it with a 780Ti that I got lying around and report back.
Come the worst, do you have any ideas on how I could make this a two step process? Would a KVM Switch work, like suggested above?
Thanks guys, we might even learn something from this.
Reply 8 of 16, by cyclone3d
The ones with the USB power are going from DP output to DVI input. Something about the DP port not being able to output enough power to power the active converter.
If you look at the Visiontek site, that adapter cable does have a converter device in the middle of the cable so it isn't just a passive cable.
YMF7x4 Guide
Reply 9 of 16, by imi
wacha wrote on 2020-02-20, 20:53:
Hi guys.
I know that is what it says... but this should not be possible, unless they really messed up something in the design process and somehow made it so that anything on pin 8 of the connector breaks functionality of the device, since that is the only pin that is on the DVI-D part of the connector that has an analogue signal... but even then, there should be nothing on that if setting DVI to a digital output.
but now that I think of it... I remember having a weird issue with a LCD before, that would not work in digital mode with a DVI-I cable... that probably had some detection method to recognize a DVI-I connection and did not switch to digital, but why they would build a DVI to DP adapter like that is beyond me, in any case I think this is a mess up on their part and they don't want to admit it.
Reply 10 of 16, by wacha
Ok, so I've tested the 780Ti and....it works out of the box. It works using both the DVI-D port and the DVI-I port, so now I'm really confused. If it were a port incompatibility it should not work when connected to the DVI-I port. If it were a bandwidth issue it should never be able to output 1440p 60Hz, but it's happy to do it. Damn, this shouldn't be so difficult, but I'm completely puzzled. Another "special" card like the Gigabyte GTX 295 or are we missing something here?
True that, my bad.
I know. Nothing makes sense here. We must be missing something...
Reply 11 of 16, by wacha
Hi again.
I've been conducting further testing for most of the afternoon and I've made some progress. At first I was trying to make the conversion work with an HD 3870 X2. No success there. Then I've remembered that during my countless searches I stumbled upon two little patchers for AMD and Nvidia drivers that claimed to remove the pixel clock limit. It seemed like a new line of investigation. So I plugged in one of my HD 7990s (DVI-I) and got to work. Default behaviour was as expected, 1080p 60Hz max resolution and the inability to show 1440p 60Hz correctly. But after running the patcher and rebooting, voilá, 1440p 60Hz by default with flawless, crisp image!
So I think this rules out the cable. With the 7990, it's now doing 1440p with 4 different configurations: one GTX 295, both my GTX 590s, my 780Ti and both my 7990s. That leads me to believe that the passive cable can actually do as advertised just fine, and that we might be dealing with a software issue. Now there's a few caveats here. Firstly, these patchers only work on HD 5000 series or newer cards from AMD or GTX 400 series or newer from Nvidia. Secondly, I only have a limited selection of cards fitting those requirements, so I cannot test that this works for every card or combination of cards. And lastly, there are some inconsistencies in the original behaviour of the cards, and we still have one card, the Gigabyte GTX 295, that works out of the box when it shouldn't, if this were a software only issue.
The ideal solution is still a DVI-I to HDMI or DP 1440p adapter/converter/scaler. Should that be possible, there would be a consistent, out of the box way of achieving 1440p across all GPUs pre-HDMI 2.0 and DP era. This workaround will at most allow someone with a setup like mine use a small selection of generations - GTX 400, 500 and 600 series from Nvidia and HD 5000, 6000, 7000 from AMD. Anything newer than that will have ample support for newer standards. Anything older is not supported by the patch. I've tried the patch on the 3870 X2s and it doesn't work. It could even be a more constrained of a selection, as both my 7990s sport 4 mini-DP connectors and I'm just using the DVI port for convenience and not having to use 700 different cables.
Does this new finding give you any ideas? I feel like this should be much easier than what I'm making it, but I'm running out of ideas. I need to test the patch with the 590s and see if it works too, for the sake of consistency.
ATI/AMD Patcher
Nvidia Patcher
Thank you.
Reply 12 of 16, by dr_st
This is interesting. If I understand correctly, you are basically overclocking the DVI link itself? By how much? I wonder if the circuitry can withstand it for long periods of time.
Reply 13 of 16, by wacha
dr_st wrote on 2020-02-22, 07:54:
That's what I make of it. I asked for help on the CRU forums but we haven't been able to understand the inconsistencies in the behaviour of the cards. I was recommended this: https://www.gefen.com/product/dual-link-dvi-m … GTV-DVIDL-2-MDP
It seems like it would do the trick, and the reviews suggest that it works as intended, but it's very expensive. I'm a spaniard, and I can only find sellers in the USA, so if I add the cost of the device, shipping, customs and VAT, I'm looking at about 250€. I might take one for the team and buy it, as it is cheaper than a new comparable monitor (32 inch, 1440p, 144Hz, curved) and I don't have space for two monitors as of now. I don't even think there's a monitor with VGA, DVI, DP and HDMI support and at least the aforementioned characteristics in the market, whatever the price.
In the meantime, I'll let you know if I find any alternative. If someone has a suggestion or something to test, please write it here. I would especially like to understand this inconsistent behaviour when the only thing that changes is the GPU. Same monitor, same OS, same motherboard, RAM, CPU, same adapter cable...
Thank you.
Reply 14 of 16, by cyclone3d
Here is an Atlona unit that should do the same thing.
ATLONA AT-DP400
Maybe that one is available closer to where you are.
Looks like there are a few on eBay. This unit has been discontinued by Atlona.
YMF7x4 Guide
Reply 15 of 16, by wacha
cyclone3d wrote on 2020-02-25, 16:52:
Here is an Atlona unit that should do the same thing. ATLONA AT-DP400 […]
ATLONA AT-DP400
Thank you. It seems the only sellers are from the States as well...but it is a bit cheaper. I think I'll buy it, after looking thoroughly for other options and/or sellers.
I've been given some very useful info at the CRU forums from the developer himself, ToastyX. I quote:
The behavior will depend on whether it's treated as DVI or HDMI. […]
Newer cards will output an HDMI signal over DVI ports if HDMI support is defined in the extension block. Older cards might only output DVI no matter what.
If it's treated as DVI, you will get a blurry image beyond 165 MHz pixel clock because that's where it switches to a dual-link signal, but HDMI is single-link, so you lose half the pixels. Renaming the patcher to whatever-patcher-single.exe will make it always send a single-link signal, but that might not work with older cards.
If it's treated as HDMI, AMD/ATI cards will output an HDMI signal over DVI ports, but only up to 165 MHz pixel clock unless the driver is patched. With the HD 7990, you shouldn't need the patch if you plug the monitor directly into an HDMI port.
NVIDIA cards will output an HDMI signal over DVI without the 165 MHz limitation, but keep in mind older cards might not have the hardware to handle higher pixel clocks because old versions of HDMI only supported up to 165 MHz. The one GTX 295 probably has a better TMDS transmitter that is capable of higher pixel clocks.
Reply 16 of 16, by darry
It's been a while, but I just ordered this one. It might fit your needs as well .
https://www.cablematters.com/pc-825-139-gold- … z-in-black.aspx
EDIT: I got it for 40$ Canadian .
EDIT : Misread your needs . That Gefen thing seems like the only option for your needs .
