First post, by maximus
- Member
I have a conundrum. A quandary. A dilemma.
I have a BFG 6800 Ultra OC AGP that I want to install in a Pentium 4 3.4 Northwood machine. The problem is, I don't have a good power supply to use with it.
AGP versions of the 6800 Ultra have two Molex connectors. From what I can gather from old reviews and forum threads, Nvidia recommended pairing the card with a 480 watt power supply or better and feeding each Molex connector from a separate cable. Each cable should have nothing else attached to it, except for maybe a fan.
I have some old power supplies with plenty of Molex connectors, but none of them has both the raw wattage and the strong 12 volt rail required for the 6800 Ultra. With newer, more powerful PSUs, you're lucky if you get one cable with two or three Molex connectors.
Seems to me like I have three options here:
1) Buy an older power supply like the Antec TruePower 480 with a high maximum power rating, a strong 12 volt rail, and lots of Molex connectors. I'm paranoid about bad caps and catastrophic power supply failures, so I hate buying old units that are more likely to have bad caps and fail catastrophically.
2) Buy a new power supply that can easily power the system and use SATA to Molex converter cables to connect the 6800 Ultra. These converter cables seem to have a reputation for caching fire (seriously), so I'm hesitant to use them with something as power-hungry as a high-end video card.
3) Buy a new modular power supply, then buy extra Molex cables on eBay (most only come with one or two) and connect the 6800 Ultra that way. This would be the most expensive option, but I feel like it would probably work out the best in the long run.
Thoughts?
