First post, by diagon_swarm
Hello everyone,
I recently had some experience with DEC PowerStorm 3D30 (2MB; early 1996) based on DEC's own TGA2 design. This card was used with their Alpha-based workstations and (in this version) it was limited to 256-color modes. I tested the card in my benchmark and discovered that it is a true OpenGL 1.0.1 3D accelerator (with extensions only for vertex arrays) and the acceleration works under Windows NT 3.5/4.0 (full ICD driver).
However, 256-color modes work with palettes and that means additional work for developers. This was well explained in this article from Microsoft (1994):
http://web.agelid.com/protect/utile/documenta … RGBA%20Mode.htm
-> You need to change the palette appropriately or modify the renderer to use only indexed colors (then you lose ability to do smooth shading and some other stuff)
Most OpenGL programs don't care and expect non-palette modes (12, 15, 16, 24 or 32 bits per pixel). They either check the configuration and fire an error (old programs where developers offer their own software rendering for 8-bit colors - like 3D Studio Max R2.5/R3) or just use wrong colors (basically anything 1998+). I was successful with LightWave 3D 5.6, which hides options for OpenGL smooth shading (if run with 8bpp) and offers only OpenGL modes without lighting (so you can still benefit from higher performance of the 3D accelerator).
So the questions are:
Do you know more OpenGL programs that support 256-color modes?
Do you know other 3D accelerator that supports OpenGL acceleration in 256-colors? (most cards switch to Microsoft OpenGL software renderer when set in 8bpp)
Cards:
DEC PowerStorm 3D30 (TGA2)
DEC PowerStorm 4D20 (TGA2)
Programs:
LightWave 3D 5.6
Btw if you want to know more about this TGA2 graphics chip, I wrote all I know in this blog post:
https://swarmik.tumblr.com/post/6123093630419 … tga2-march-1996
Vintage computers / SGI / PC and UNIX workstation OpenGL performance comparison
Reply 1 of 7, by Putas
While I have nothing to add, I just want to thank you for those interesting findings.
Reply 2 of 7, by diagon_swarm
To my surprise, 3D Labs Permedia2 provides HW accelerated OpenGL under Windows NT4 even with 256 color modes. Sadly, there is still the problem that first and last few colors in the palette are reserved by the OS, so too bright and too dark colors are corrupted when using the pallete as RRRGGGBB. There is a way to force Windows into reserving only two colors (black and white - the first and last color in the palette). However, that must be handled in the program and it is suitable only for full-screen apps.
I tweaked the LUT tables for Quake II, so it does not use too dark or too bright colors. The result is the hardware accelerated Quake II in 256 colors... with bilinear-filtered textures!
I understand that this is so weird stuff that nobody cares, but I had to share it anyway 😁
Modified Quake II (different LUT):
The attachment IMG_20230316_160657.jpg is no longer available
Unmodified Quake II:
The attachment IMG_20230316_142350.jpg is no longer available
The attachment IMG_20230316_142427.jpg is no longer available
The attachment IMG_20230316_142522.jpg is no longer available
Reply 3 of 7, by mtest001
Well done, the result looks quite interesting...
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB32 PnP + Sound Canvas SC-55ST = unlimited joy !
Reply 4 of 7, by TM30
Can someone please Upload a Driver for the DEC 3D30?
Reply 6 of 7, by TM30
Yes my card works with generic windows xp vga driver on a x86 machine (Dual PIII 850Mhz, ASUS P2B-DS) but of course it only uses the cirrus logic chip there for 2D. I am curious to see if i can get the 3d part working on x86. Of course i would use NT4 then.
Reply 7 of 7, by devius
diagon_swarm wrote on 2023-12-10, 20:44:
What kind of performance were you getting?
Retro Coisas no YouTube
