Reply 20 of 23, by ruthan
- Oldbie
I solved shaking with bigger passive cooler on Silicon image chip, fortunately card has some screw holes around.. so i found some bigger chip passive from some vrm module or so.. paint new holes.. found someone willing to drill new holes and its running for hours.
Now im not only sure about memory chips, because they are without any passive, so far no atefacts etc.. but once i got just black screen instead of picture in Unigine Sactuary.. but it was otherwise still rendering regarding of FPS counter.. but because screensaver and monitor shutdown was infolved, memory chips could be fine, this not typical problem for them. In any case, i learned that problem was really Silicon image chip and its cooling - good to know, i theory i can fix other cards with same issue.
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
