bloodem wrote on 2022-02-10, 10:06:
Damn, I really need to get my hands on one of these boards. The issues you guys are having with them are really intriguing. Me likey! 😁
mwdmeyer wrote on 2022-02-10, 10:10:
Hah yeah that would be great 😁
Well, thanks to @RockstarRunner, I have been playing with the GA-5AA rev 3.2, and... man, what a ride! 😀
The board has a revision B1 South Bridge and revision G North Bridge with internal tag RAM (there is no external tag RAM present), so it can cache up to 512 MB of RAM, which I was able to confirm (there is no performance difference between 128 MB and 256 MB of RAM).
I first tried the board with a GeForce 2 MX and then a GeForce 2 Ti. Both of them work perfectly at AGP 1X with driver 7.76 (there are random freezes @ AGP 2X, but that's to be expected with most SS7 boards). Anyway, performance @ AGP 1X is identical to that @ AGP 2X, so no biggie.
The board works fine at FSB 110, 115, 120 (it might also work at 133... though I haven't tried it).
TEST SYSTEM:
CPU: AMD K6-2+ 570 OC @ 605 MHz (FSB110 x 5.5)
VGA: GeForce 2 Ti (OC @ Ultra speeds)
SOUND: NO SOUND CARD
ALI AGP DRIVER: 2.13
nVIDIA DRIVER: 7.76
ALI AGP TOOL CHANGES:
- AGP RATE: 1x
- GAT MODE: 2
- FRAME BUFFER SIZE: ALL
- WRITE ALLOCATION: Enable without Hole
BENCHMARK RESULTS:
3DMark99 default: 4836 3DMarks / 8418 CPU Marks
3DMark2000 default: 4328 3DMarks / 267 CPU Marks
GLQuake 640 x 480 x 16: 160.3 FPS
Quake 2 OpenGL 640 x 480 x 16: 93.2 FPS
Quake 2 OpenGL 3DNow! 640 x 480 x 16: 105.3 FPS
Quake 2 Software 3DNow! 640 x 480 x 16: 32.7 FPS
Quake 3 640 x 480 x 16: 61.1 FPS
MDK2 640 x 480 x 16: 61.67 FPS
Expendable 640 x 480 x 16: AVG 44.12 FPS / HIGH 76 FPS / LOW 31 FPS
These results are very solid for a SS7 system (but still lower than what I get with the Asus P5A rev 1.04).
The most important speed boost comes from the higher FSB, which seems to be a bottleneck for K6-2/3(+) CPUs.
So, obviously, the next thing I tried was a Voodoo 3 3000 AGP... and, boy, was I disappointed! As others have mentioned, performance with this video card is pretty bad, ~ 50% lower than on other ALI or VIA based boards:
3DMark99: 2538 3DMarks
GLQuake 3dfx Glide: 126 FPS
Quake 2 3dfx Glide: 54 FPS 😮
I literally tried everything humanly possible, tested every combination of BIOS settings, tested both the F6 and F7b BIOS ROMS (both support K6-2/3 "+" CPUs), tested every combination of AGP tool settings, multiple ALI AGP drivers, multiple Voodoo 3 drivers (including some newer unofficial ones)... nothing worked.
Then I also tested a PCI Voodoo 3 3000 to see if this was somehow related to an AGP bug or not... and, it's not. The PCI version has the exact same problem.
So, now I'm starting to wonder if maybe this is a bug/incompatibility between the ALI "G" revision north bridge (or its implementation on these Gigabyte boards) and Voodoo cards.
To try and get to the bottom of this, I'd be interested to hear from other Gigabyte GA-5AA owners (or even GA-5AX owners) that are using them with Voodoo 3 cards:
- what are your 3DMark99 / GLQuake / Quake 2 scores (ideally, you should first use the ALI AGP tool and set FRAME BUFFER SIZE: ALL / GAT MODE: 2 / WRITE ALLOCATION: Enable without Hole, and then restart the OS )
- what motherboard revision you have
- what chipset (north bridge) revision your motherboard has.
CONCLUSION:
- The GA-5AA does not have any issues with K6-2/3 "+" CPUs
- It works perfectly fine (it's both fast and very stable) with GeForce 2 cards
- something kills the performance with Voodoo 3 cards, my initial guess is an incompatibility between these cards and the chipset (might only affect revisions "G" of the chipset)
Not sure if there are any GA-5AA boards with the revision "H" north bridge (I know there are some late GA-5AX rev 5.2 boards that come with this revision). It would be interesting to see how those perform with Voodoo 3 cards as well (although this revision apparently only fixes the "suspend to RAM" function).
In the upcoming weeks, I'll also test 2 x Voodoo 2 cards in SLI, I'm very curious to see if they suffer from the same bug.
2 x PGA132 / 5 x Socket 3 / 9 x Socket 7 / 12 x SS7 / 1 x Socket 8 / 14 x Slot 1 / 5 x Slot A
5 x Socket 370 / 8 x Socket A / 2 x Socket 478 / 2 x Socket 754 / 3 x Socket 939 / 7 x LGA775 / 1 x LGA1155
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
