Reply 40 of 62, by Madao
Yes, i was with 14 Chip. It is planning in dosforum with ~ 12 people.
Trio64V+, i would make it. Main goal is ViRGE VL , which their chip is pin compatible with Trio64V+. Probably fastest VLB video card for DOS.
VL-Mode at ViRGE & Trio64V+ = max 2 MB RAM. Trio64V+ & ViRGE has only 135Mhz DAC , despite this fact, it is good chip from their time.
I have check 968VL performance on 486DX2-66 w. PAT48AV Board , this mainboard has very good memory output.
By 66Mhz clock: no difference with S3 Trio64. I must check with faster CPU ( PAT48AV haven't 3.3V regulator 🙁 )
Soon , not today, i check 968VL card with Vision964 chip. This Chip is much better avaible. (but not cheap, better as nothing)
Greetings
matt
