Reply 60 of 169, by Madao
Ok, i make think about fearture connector in second 765VL-draft. It has low prio, sorry.
I hope, we got 15 minimum order for PCB in a german forum. Then i can order 25 pieces and sell 10 pieces pcb with compoment list here.
Who want it ? Pleas write me a PN with country, where you live. (i can ship worldwide, but i prefer: I ship more pieces to one people in USA and this people share pcb)
Notice:
One has borrowed me ARK1000VL and it is compared with Trio64V+ VLB on System Abit AN4R307 & AMD 5x86 @160Mhz.
Ark1000VL is faster than Trio64V+, but distance is in most case zero, only DOOM is ARK slight faster ( ARK 59.04 / Trio64V+ 58,63)
regards
matt
Reply 61 of 169, by Madao
PCBs is arrivied, since friday. ( i got 50 pieces, over half is reservered )
I'll write few people for selling of pcb. Pleas be patient.
regards
matt
    246.44 KiB
Reply 62 of 169, by keropi
Madao wrote on 2021-09-13, 03:42:
PCBs is arrivied, since friday. ( i got 50 pieces, over half is reservered ) […]
regards
matt
nice! I've been monitor this thread on and off thru time , kudos on finishing the project!!!!
I am interested in one or two if they can be spared 😀
Reply 72 of 169, by matze79
Thanks, got my PCB + Building Kit.
Did not yet assemble it 😀
Reply 73 of 169, by Madao
Now: I can sell pcb
a pcb cost 8 USD and 10$ outside EU, inside EU 5,5$
I have ~10 piece PCB left.
Pleas write me a private message, if you're interessing on pcb.
Of coruse, only trio64V+
But Virge (325) may run on this PCB with patched ROM and heavy modified virge driver.
Reply 74 of 169, by Madao
And a next message.
I got couple graphic card, one is Trio64V2/DX. This chip has official no VLB support. I have soldered him to VLB . Yes, VLB Support is removed. (It locks 486 local bus very hard )
Reply 75 of 169, by feipoa
Do you know if there is sufficient space surrounding the memory pads to install SOJ-40 sockets? I suspect not due to the caps.
Reply 77 of 169, by maxtherabbit
Madao wrote on 2021-10-28, 15:53:
No, it is never designed for using of SOJ Socket. (i hate SOJ /PLCC SMD Socket 😒 )
I don't much care for them either but there is a time and a place to use them.
Not to mention the footprint is identical so it doesn't take much to accommodate them (physical clearance)
