First post, by Smack2k
- Oldbie
Hoping someone can help me out.....I had a sheet with these values listed, but cant find it.
I removed some bad caps from my Ti4400 and am now (several months later) going to replace them, however I cant find the sheet that had the values on it.
Does anyone know the following capacitor uF / Temp / Voltage / etc for the following locations
C1286 - Top Right of Card about a third of the way in
C1287/1288 - Both are listed around this cap area. Its to the right of C1286
C1298/1299 - Both are listed around this cap area. Upper Right Corner. Would be the Upper Right most Capacitor
C1366/1258 - Both are listed around this cap area. Far Right side of card, a little past half way down. Would be the 5th Capacitor down if you count from the top
Thanks if anyone can help me out here!!
