First post, by Superpuissant
Hey there!
I am deseperately trying to install drivers for this video card: https://www.ebay.fr/itm/333759696360
(presumably a Radeon 9600 Pro 256 Mb) for windows 98 using the Catalyst 6.2 drivers without success...
Could someone help me to identify the card and hopefully find the proper drivers?
Thanks!!
Reply 2 of 13, by Superpuissant
I've tried installing the drivers both automatically and manually (by selecting different types of Radeon 9600 Series card). Each time I end up with the default 640x480 16 colors resolution and an error message.
Reply 3 of 13, by darry
Superpuissant wrote on 2020-11-03, 16:42:
Hey there! […]
Hey there!
Thanks!!
What mainboard do you have and have you installed appropriate chipset drivers for it ?
Reply 4 of 13, by Superpuissant
I have a ASRock P4i65G motherboard with an Intel 865G chipset, coupled with a p4 2.8 ghz and 512 Mo Ram.
I am using Windows 98 SE and I have indeed installed the chipset drivers and I assume these are the right ones as I have successfully used the computer with many other AGP graphic cards (radeon 9200, NVidia Geforce FX 5500, Geforce 6600 GT). All of them have been recognized without issue (agp x8). This one is the only one that resists...
Reply 5 of 13, by darry
Superpuissant wrote on 2020-11-03, 17:28:
It sounds like you are doing everything right . If other cards, both older and newer work, your 9600 may be defective in some way. Or maybe you have hit a strange incompatibility . Do you have another motherboard to test this video card ?
Reply 6 of 13, by Jorpho
Superpuissant wrote on 2020-11-03, 16:53:
Okay, but wouldn't it be useful to know where you found the drivers you are trying to use?
darry wrote on 2020-11-03, 17:38:
If it comes down to that, I would suggest testing the computer with a live Linux distribution (either on a bootable CD or a bootable USB drive).
Reply 7 of 13, by darry
Jorpho wrote on 2020-11-03, 17:54:
Okay, but wouldn't it be useful to know where you found the drivers you are trying to use? […]
That is a very good idea .
Reply 8 of 13, by Superpuissant
Better picture of the card in question:
https://ibb.co/jTRZfj6
The drivers are the legacy ones from AMD website: https://www2.ati.com/drivers/6-2_wme_dd_cp_30314.exe
Thanks for the suggestion, I will try with a live Linux image, let see how it goes
Reply 9 of 13, by Jorpho
I would be inclined to try the Win9x Omega drivers, but I'm not sure what exactly the appropriate version would be. I think https://retrosystemsrevival.blogspot.com/2019 … ivers-2637.html might work - although the page says it supports up to the Radeon 9250, the screenshots of the installation dialogs suggests it supports later cards.
Reply 10 of 13, by Superpuissant
Jorpho wrote on 2020-11-03, 18:59:
Gentlemen, I am more and more puzzled...
I did boot on a live Xubuntu 18.04 and the card worked perfectly fine, it displayed a crystal clear 1280x1024 image and was listed as a radeon 9600 RV350 is what I find when displaying the list of PCI devices: https://ibb.co/6W970cr
I tried the omega drivers which seems indeed to support the 9600, but same error, device not found.
Soooo frustrating...
Reply 11 of 13, by Jorpho
Do you have any other unusual software installed? Does the Catalyst Control Center work correctly? (I remember that certain overzealous firewalls can prevent it from functioning.)
Reply 12 of 13, by Superpuissant
Jorpho wrote on 2020-11-03, 20:42:
No, nothing fancy in here, I just put that old thing together to enjoy good old windows 98 gaming. Damn, I forgot how far we went since this time.
Catalyst Control Center does not work at all, probably because the card is not recognised properly?
Reply 13 of 13, by Jorpho
Superpuissant wrote on 2020-11-03, 21:16:
I also vaguely recall that it requires the .NET 2.0 runtime.
