First post, by mjd93
Long-time lurker, first-time poster; unfortunately, I've run into a problem that's proving rather challenging, and I figured I'd seek the wisdom of the Vogons posters. (Please let me know if this is being posted in the right place, happy to move it across if need be!)
I recently upgraded the video card in my retro Win9x build from a failing MX440SE (64MB) to a Galax FX5500 (256MB), but have run into nothing but issues with my new purchase. Having tried with both Windows 98SE and XP, I'm getting numerous Code 12 errors in Device Manager. It seems as though the memory ranges that my FX5500 is trying to use clash with the resources used by the motherboard.
Win98 claims that it's clashing with the "System board extension for ACPI BIOS", but even changing my system type back to a standard PC hasn't yielded any success, even under XP.
Thus far, I've tried;
  • Disabling ACPI from the BIOS (no luck)
  • Disabling unused ports in the BIOS (serial/parallel ports primarily)
  • Disabling and enabling reserved IRQs for VGA
  • Disabling ACPI within Windows XP; tried within 98SE as well but with no real luck
  • Reinstalling both the VIA chipset and nVidia drivers
  • Upping the AGP aperture setting; it maxes out at 128MB even with the latest BIOS update
  • Updating the BIOS; did this in the past to fix another issue but there's nothing newer than April '01 on the Gigabyte website
My system specifications are as follows:
CPU: Pentium 3 800EB (800Mhz)
MB: Gigabyte GA-6VXE7+ Rev 1.0 (with VIA Apollo Pro chipset; had to make do with what was available!)
RAM: 512MB SDRAM
CPU: Galax FX5500 (256MB VRAM)
Storage: 1x CF-IDE adapter (usually a 16GB card), 1x 80GB IDE HDD, 1x CD-RW, 1x DVD-RW, 1x 3.5" FDD
Sound: Creative Sound Blaster Live! Value (PCI)
Other PCI cards: Intel 10/100 NIC (can confirm model number)
OS: Windows 98SE (with a few unofficial updates and such), Windows XP SP3
I'd like to get the configuration working if possible but am realistic about the possibility I'll have to cut my losses and switch back to my old card/change motherboards.
Thanks in advance! I'm hoping that after finally biting the bullet and making an account, I can contribute back to the site that's already given me so much guidance. 😀
Reply 2 of 15, by mjd93
Thanks for the quick reply!
Gave that a try but unfortunately had no luck there. Removed any VIA drivers I could see (had the 433 drivers installed previously) and didn’t have any issues through the installation around file versions. Tried both turbo and normal mode within the installer for the VIA AGP VxD but it didn’t appear to change anything.
I also tried manually removing the “VIA CPU to AGP controller” within Device Manager, which allowed Windows 98SE to re-detect the GPU, but after a restart I got the same behaviour.
I’ve imaged my 98SE install so can try a fresh install as the next step, but feel as though I’m going to run into the same issue down the line...
Reply 4 of 15, by mjd93
Repo Man11 wrote on 2021-03-17, 01:00:
Have you tried installing without the sound card?
Just gave it a try; no joy. Same error as earlier, still conflicting in the same Memory Ranges with the same ACPI BIOS extensions.
I took some screencaps of the resources window in Device Manager, will attach them when I can transfer them across.
Reply 5 of 15, by Repo Man11
Someone on Vogons recently had an issue similar to this and they were able to fix it by upgrading the BIOS of the video card.
It was this one, where they weren't able to use the floppy drive when they installed GeForce 3: Intel D850GB mainboard with floppy drive issue when geforce3 installed
Reply 7 of 15, by mjd93
Apologies for the double post/mild necro, figured I'd give an update for anyone who's encountered a similar issue.
I haven't been able to locate an updated BIOS for the Galax FX 5500 (lots of dead links on my search, closest I found was an FX 5200...), but seeing as how it's largely a memory range clash, I figured trying it with a different motherboard wouldn't be a bad debugging step. My current motherboard (Gigabyte GA-6VXE7+) only had one BIOS update available on there, which doesn't bode well. Even the AGP aperture settings only go up to 128MB which seems a little anemic for the hardware.
I've tried multiple driver versions, even including the patched 82.69 by Maximus-Dexim (http://www.mdgx.com/files/nv8269.php) but with no luck. Not sure if my configuration is particularly ill-equipped so YMMV.
I'm now looking for a slightly more up-to-date replacement that's at a reasonable price bracket to see if I can get this card working, otherwise I'll be getting in touch with the seller of the card.
Reply 8 of 15, by texterted
Have you tried it with only 256mb of system ram?
Cheers
Ted
98se/W2K :- Asus A8v Dlx. A-64 3500+, 512 mb ddr, Radeon 9800 Pro, SB Live.
XP Pro:- Asus P5 Q SE Plus, C2D E8400, 4 Gig DDR2, Radeon HD4870, SB Audigy 2ZS.
Reply 9 of 15, by dries_86
can you check this setting in BIOS:
Resources Controlled By : This setting tells the computer to either set IRQs automatically or to allow for all devices to be assigned IRQs manually. Manual IRQ selection can be quite challenging and is usually only required when working with older, non-PnP compliant peripherals. The recommended setting is: AUTO(ESCD).
Reply 10 of 15, by mjd93
Apologies for the slow replies, had a lot of commitments (regrettably not involving retro computing) over the past week.
texterted wrote on 2021-04-05, 02:37:
No change unfortunately.
dries_86 wrote on 2021-04-05, 07:07:
can you check this setting in BIOS: […]
Playing around with those settings at the moment; unfortunately, Windows is complaining about memory ranges being taken, and my BIOS only allows me to change settings around IRQs and DMA. I've attached the PNP/PCI config screen within my BIOS. There are no BIOS updates available from the manufacturer either.
    655.16 KiB
    PNP/PCI Configuration screen from Award BIOS
Reply 11 of 15, by mjd93
Screencaps of the error that I'm getting attached.
Reply 13 of 15, by mjd93
No luck with adjusting the AGP aperture back down unfortunately, tried with both the lowest value (4MB) and 32MB with the same results.
I’m searching around for a slightly newer P3 motherboard for a decent price, but will have to persist with the MX440SE for the time being.
Thanks to everyone that’s submitted suggestions; there’s only a couple of lines of inquiry that I can think to pursue (trying to dig up an unofficial/patched BIOS that allows for blocking out of memory ranges as per dries_86’s suggestion, or trying to find an alternate BIOS for the FX 5500 that’s a little less needy with memory ranges) but will be sure to update the thread if there’s any joy there.
Reply 14 of 15, by RetroLizard
I'm having similar problems with the same card, an FX5500
My specs are as follows
CPU: Pentium 3 500Mhz
MB: Gigabyte GA-6BA rev 3.0(I think)
RAM: 128MB SDRAM
CPU: EVGA FX5500 (256MB VRAM)
Storage: Hard Drive, 1x CD-RW
Sound: Aureal Vortex 2 (A3D8830A2 chipset)
Other PCI cards: Linksys EG1032 v3 NIC, pair of Voodoo 2 cards (both Creative brand)
OS: Windows 98SE
Reply 15 of 15, by tauro
mihai wrote on 2021-04-14, 19:39:
Can you change AGP aperture to 32 MB or lower? I had the same issue and this change fixed it.
I was having this issue with a FX5500 128-bit 256MB from MSI 8911 Ver 3.30. with the GA-5AX Rev 5.2.
Setting the AGP aperture to 32 MB fixed it! Thanks for that tip!
