First post, by 386SX
Hello,
I've found lately this Rage 128 Pro "Ultra" card, is an identical card of the one that can be seen here @ vgamuseum.info ( http://www.vgamuseum.info/index.php/component … e-128-pro-ultra ) the first on the left, same P/N 109-73100-01 code but it has all four ram modules installed, 32MB 6ns SDRAM two for each chip side, I've installed latest Phil site Win ME drivers (on Win 98) and detected by Everest as Rage Fury Pro/Xpert 2000 @ 133/133Mhz 32MB 128bit (R128 Tweaker reads 131/131Mhz but interesting even itself can't read the Info tab details). PowerStrip has problem reading it as it see a Rage 128 GL not reading the freqs. I suppose this is one of the many OEM versions anyway the ASIC version is seen as 5446. I've installed it on a 440BX/P-III 600 but I find that while it's indeed a "fast" good quality card, does the MMC softwares work or only the retail version was working with it? The Detail page reports the RAGE 128 PRO ULTRA, ID 5446, a bios number 001.001.003.002 and dated November 2000, the card PCB manufactured in March 2002.
Anyway it' very good quality vga output card, a good 3D acceleration (3DMark2000 get a 2346 score, 3Dmark99 surpassed 5000 points easily) but would be interesting to test the video decoding engine at the top of those times.
Thanks
