Pentium MMX 233 aiming for the stars!
Reply 40 of 75, by Garrett W
Imperious wrote on 2022-02-14, 10:54:
OK Yes this is total cheating, but I bet a few were wondering.
Motherboard is Epox EP-MVP3G5.
I think it's still fair game. Thanks for the tests, they paint a nice picture on what's going on here. I presume 3x100 was unstable eh?
Joseph_Joestar wrote on 2022-02-14, 11:31:
Garrett W wrote on 2022-02-11, 21:22:
Considering this PCI variant of the AGP8x version of MX440 probably came out rather late, I don't think I can really go much farther back when it comes to using older drivers, 43.45 are already from early 2003.
I use 40.72 WHQL drivers on my AGP8x MX440 and they work just fine.
This is with an actual AGP card mind you, so I'm not sure if it applies to your PCI version as well. Might still be worth trying it out.
Apparently I could go one step further back with 40.71. Tempting to give it a try and perhaps even earlier drivers, attempting to force vanilla MX440 drivers, but I just can't justify the time I'll have to spend 😜.
Reply 41 of 75, by Imperious
Garrett W wrote on 2022-02-14, 12:21:
I think it's still fair game. Thanks for the tests, they paint a nice picture on what's going on here. I presume 3x100 was unsta […]
I never tried 3x100 and that was because 83x3.5 (292) gave blue screens before even getting to the desktop. I didn't want to try 3v.
I only have one P233mmx which I got with a nice AT Intel TX board cheap from ebay last week. I'll give a that a go next.
Reply 42 of 75, by bloodem
Imperious wrote on 2022-02-14, 12:31:
You can try 3.0/3.1V without any issues, just make sure you have a more robust heatsink/fan (a small to medium sized socket 370 cooler should be fine).
I only have one Pentium MMX which is stable @ 300 MHz with only 2.9V, the others all need 3.0/3.1 for 100% stability.
2 x PGA132 / 5 x Socket 3 / 9 x Socket 7 / 12 x SS7 / 1 x Socket 8 / 14 x Slot 1 / 5 x Slot A
5 x Socket 370 / 8 x Socket A / 2 x Socket 478 / 2 x Socket 754 / 3 x Socket 939 / 7 x LGA775 / 1 x LGA1155
Current rig: Ryzen 5 3600X
Backup rig: Core i7 7700k
Reply 44 of 75, by furan
BitWrangler wrote on 2022-01-30, 02:17:
It's a battle between driver overhead crippling the card from feeding the GPU fast enough and the actual capability of the GPU architecture...
Spoiler
Fastest AGP video card for Super socket 7 platform?
If you're going to talk about drivers, know that sometimes driver code would make a card faster than it would be on its own, by doing things like batching calls together. Really anyone who wants to talk about 90's/2000's graphics drivers should read this: http://www.azillionmonkeys.com/qed/accelerator.html
Reply 45 of 75, by Imperious
bloodem wrote on 2022-02-14, 12:41:
OK I tried 300mhz, and still got blue screens and lockups with 3v and 3.1v. I have 3 other P200 mmx chips. Maybe at a later time but for now 285mhz will do.
I have a decent heatsink but I think this particular chip won't do 300mhz.
Reply 46 of 75, by Imperious
It's a shame this motherboard cannot post at over 100mhz fsb with the L2 Cache on because fsb makes a huge difference. The 250mhz with 100fsb is not far off the 285mhz with 95fsb.
Reply 47 of 75, by Sphere478
Imperious wrote on 2022-02-15, 08:32:
What gpu?
Sphere's PCB projects.
Reply 48 of 75, by Imperious
Sphere478 wrote on 2022-02-15, 13:50:
What gpu?
GF3 Ti200
Reply 49 of 75, by Sphere478
Imperious wrote on 2022-02-16, 00:12:
What gpu?
GF3 Ti200
Sweet! I think you have the thread record!
I was wondering if gf2/3 was gonna be the leader like it is in the k6 thread. Looks like it may be.
Reply 50 of 75, by Aebtdom
Oh nice! I wonder what a voodoo 2 sli setup would do on that cpu speed! Since your gf3 still got beaten at the 233mhz standard clock due to driver overhead. 🤔
Builds:
Xp2400+ gf3 ti200 + vd2 SLI 12MB + 768MB + SB live @ WinXP & 98 Dualboot.
MMX233 + S3trio 3D/X2 8MB + 3Dfx Voodoo 1 + AWE64 + 64MB SDR @ msdos / win98.
Reply 51 of 75, by Imperious
Aebtdom wrote on 2022-02-16, 04:27:
I could actually give that a try. I got 2 of those new old stock 12mb voodoo2's from Russia a few Years back when You could buy them for $60 or so. I would have to make a SLI cable though.
Maybe in a month or so as I have other things to do in the meantime.
I was using driver 12.xx. I did use 7.xx for the K6 benchmarking so would be interesting if I got higher numbers.
Reply 52 of 75, by Aebtdom
Well you could first try 800x600 on a single 12mb card. I dont even think one card is a bottleneck with this cpu.
Builds:
Reply 53 of 75, by meljor
Imperious wrote on 2022-02-15, 07:54:
Mmx cpu's can do 3,3v no problem, lots of guys upgraded older non mmx boards with mmx cpu's and used them at 3,3v. To be extra safe you can use a good cooler but otherwise they will do fine.
Reply 54 of 75, by BitWrangler
meljor wrote on 2022-02-16, 19:31:
I used to be doubtful about that, but maybe I was thinking Vmax was 3.3V, recently taking note that it's 3.8V means I'm no longer concerned. However, you do wanna make sure you're not running 3.5 or 3.6V with an I/O voltage boost setting, because if the "3.3" goes up to that, as some motherboards are set up (They've only got the one regulator maybe, how do you think they're gonna get 3.3 and 3.6 out of it?) then maybe that would tend to burn out the CPU in a few months.
Reply 55 of 75, by Imperious
I have all the non documented voltage settings for this Epox motherboard. There is no chance of ever hitting over 3.3v as it won't do 3.4v or 3.5v no matter what I do with the switch block.
I'll have another try with the MMX with higher voltage and see what the Voodoo2 can achieve.
Reply 56 of 75, by Sphere478
Imperious wrote on 2022-02-17, 00:16:
Sometimes switching the switch block with power on will give 5v core. I encountered that on a Kingston power leap once while documenting settings 🤣
Reply 57 of 75, by Imperious
I've re-run most of my previous benchmarks with 7.58 driver, it's a fair bit faster. I tried 3.2v with the cpu at 300mhz, still blue screens. I'm not wasting any more time with this cpu aiming for 300mhz. I might put my 200mmx in at a later date. Also I have a Tillamook cpu that may work with this motherboard if I do the cpu mod.
Reply 58 of 75, by Sphere478
Imperious wrote on 2022-02-17, 13:01:
For some reason the 233mhz screenshot is corrupted. The score was 1340
the score was corrupted in the screenshot? weird..
can you upload the driver you are using in a zip please I'm having trouble finding a working version that has a working download link
Reply 59 of 75, by cyclone3d
Would benches with dual CPUs be ok?
Yamaha YMF7x4 Guide
