First post, by Sphere478
I’m looking for people who own these cables to report their experiences.
I need (preferably) a self contained active cable that gets it’s power from the port and converts the vga video from the card into a hdmi signal that my 4k tv will like.
I have a few converters. One never works, (may be dvi to vga not vga to dvi) and one that is vga to hdmi and only works (poorly) on very select resolutions.
I need it to work in post, bios, dos, windows, and 1920x1080 or whatever my vga card supports on output. If it’s a 4:3 it should appear with black bars on the side, if it’s 16:9 it should fill the screen. You know, something that works properly.
What are you guys using?
Sphere's PCB projects.
Reply 1 of 5, by darry
Sphere478 wrote on 2022-02-18, 05:00:
I’m looking for people who own these cables to report their experiences. […]
I suggest an Extron RGB-DVI300(A) or Extron RGB-HDMI-300 . The 60Hz output should be supported by practically any TV .
If you know for a fact that your TV supports 70Hz input at oddball resolutions, an OSSC would be an option .
As you will be using a TV, display aspect ratio should be controllable on the TV itself .
Reply 3 of 5, by darry
Pierre32 wrote on 2022-02-18, 05:50:
A fun place to be, IMHO . 😉
EDIT: BTW Pierre32, parlez-vous français ? (Do you speak French ?).
Reply 4 of 5, by Pierre32
darry wrote on 2022-02-18, 06:29:
I do not! I just enjoy the French version of my Anglo name 😁 And occasionally the Italian or Spanish.
Reply 5 of 5, by darry
Pierre32 wrote on 2022-02-18, 07:12:
Cool! My screen name is derived from my middle name. It is in no way inspired by the Darry character in S.E. Hinton's novel "The Outsiders" (or its movie adaptation, though) .
Ironically, us retro amateurs/enthusiasts are, in a way and to a point, outsiders in our own right.
