First post, by Meatball
- Oldbie
Before I send this away for fixing, I thought someone here might be able to tell me something obvious I am overlooking.
This Obsidian2 has only output and no passthrough - it's from an Arcade unit. Windows sees the card and drivers for Voodoo2 or Obsidian install OK. The drivers which work best are Obsidian2 Release 6C or Fast Voodoo 4.6, and that only means I've gotten the furthest functionality with them. Others probably work fine, but I'd have to reformat the system each time to try a different driver, OS, and DirectX combination.
Monitor 1 (LCD) is connected to a Riva 128ZX (which looks plain awful on an LCD, but fine on CRT.. I digress..)
Monitor 2 (CRT) is connected to the Obsidian 2 90-2440.
Anyway, all the control panel items show up for Voodoo2 drivers. When I activate 3D, I can see the card doing "something" from monitor 1. When I run DXdiag, the spinning cube runs, but I can't see anything - monitor 2 never engages. When I tried Turok in Benchmark mode, same thing. Monitor 1 shows "Glide 3D DLL initialized..." but nothing shows up on monitor 2. I can hear the game running, though.
10MB Total memory
2MB Frame Buffer
4MB per TMU (2x)
Does anyone have any ideas what is going on or what I am missing?
Thanks much!
