First post, by Kahenraz
This is an option exposed by ATI's catalyst drivers (6.2 in my case, on Windows 98). It's located at:
HKLM\Software\ATI Technologies\Driver\0001\atixhal
Reply 3 of 4, by PC Hoarder Patrol
Kahenraz wrote on 2022-06-17, 11:33:
Thank you. Do you have any idea how it might affect things visually?
Sorry no...seriously outside my comfort zone but, at a guess, maybe some form of toggle to select VMR pitch values over other possible pitch values to avoid / fix some form of screen corruption???
Check this link (and the last para) for more info - https://docs.microsoft.com/en-us/windows/win3 … width-vs--pitch
Reply 4 of 4, by Kahenraz
Thank you, this is very interesting. I have naively thought that the pitch was also the width in bytes. I guess this is a very common misconception. When you access a frame buffer, I hadn't thought about a cache being on the line like that, or even in the same memory allocation.
