First post, by theelf
Hi, recently i bought a nice Armada 1750, very nice Pentium 2 machine with ISA ESS sound card, but with a horrible ATI Rage LT. The bad for me was no Windows 3.1 drivers, but the worst was the generic SVGA driver + vesa patch is not working, with graphics problems on screen, not usable at all
I start trying diferent ati win drivers, vesa drivers like Scitech ones, etc no luck
Finally i found a old Mach64 vesa utility from ATI, that did nothing in the Rage LT exept one option...
s Enable Single Window Implementation
The utility name is M64VBE.COM
I atach in post, and atach the svga vesa patched driver!
Enjoy 800x600x256 in Armada 1750 and maybe other rage LT notebook!
    svga256.zip
    40.87 KiB
    52 downloads
    64VBE221.EXE
    174.02 KiB
    54 downloads
Reply 1 of 4, by Jo22
Thanks ! 🙂👍
Reply 2 of 4, by RetroTechChris
So, as it ends up, there is actually a native ATI driver that will work!!
I stumbled across this page in German: https://www.tech-ecke.de/index_quereinstieg.h … armada_1750.htm
Translating the relevant section:
After I had actually already given up hope, I found three ATI driver CD images on win3x.org which, in my desperation, I simply tried one after the other and was finally successful with the third and last image "Pilotes ATi - r530 (390.3 MB)". . Of course you can suck the complete image, burn it and install it from CD or just take the Win3x extracted from the CD under Downloads below (unpack and run ATISETUP.EXE, then click on the first button [Show driver] and follow the instructions.. .).
After installing and restarting Windows, open the newly added "ATI DeskTop". Under "Screen adjustment" button [Select monitor] and then button [Special] I have set the resolution "1024x768" and "60Hz without interlacing". Then in the "FlexDesk+ control window" set the two sliders "Display size" and "Desktop size" to 1024x768 and, bang, I was able to enjoy Win3.11 in a 1024x768 resolution.
An important setting is to deactivate the DPMS, this setting can also be found on the ATI desktop right next to the "FlexDesk+" button. If you don't set this setting, the graphics card or the monitor hangs when the power-saving function is initiated and only confused pixelation can be seen on the screen.
I didn't hunt down the CD, but did download the file at this link, and it works beautifully! Currently sent to 1024x768x32K colors: https://www.tech-ecke.de/basteleien/download/ … t_pro_win3x.zip
Hope this helps someone.
Now if only I can get that pesky ESS 1869 audio to work properly. Working on it 😀
theelf wrote on 2022-07-12, 14:33:
Hi, recently i bought a nice Armada 1750, very nice Pentium 2 machine with ISA ESS sound card, but with a horrible ATI Rage LT. […]
Reply 3 of 4, by RetroTechChris
For the curious, the full ISO appears to be located here in the list! http://www.win3x.org/win3board/viewtopic.php?t=571#p3411
RetroTechChris wrote on 2023-01-07, 21:56:
So, as it ends up, there is actually a native ATI driver that will work!! […]
Reply 4 of 4, by theelf
Hey!!! thanks!! grrat find!! im traveling for work, as soon arrive home i will try!
i do t need more than 256 colors, but if driver support dci willbe cool to watch videos
Thanks a lot, i will feedback as soon i can
