First post, by T-Squared
- Member
I finally got my dream motherboard, and the monitor setup I wanted to be able to use.
However, there's a problem I've been having with the Catalyst installation programs, to be able to use the Radeon 7000 video card that I got. I'm not having a problem with the drivers; those I found a workaround for. It's the display control panel that I need, to be able to set up my internal video, and TV-out connection. The setup shows the standard"InstallShield Wizard is setting up your system" window, and then nothing happens. As I'm typing this, I've had an installation hanging for 15 minutes, waiting for it to do something, just in case the process is really that slow.
Previous attempts have forced me to quit the install, which brings up a "Remote call failed" error.
Is there something I can do to make this work?
