First post, by RaverX
What is the maximum length of a SLI cable for a pair of Voodoo2 cards? I don't think there's an official answer, since (I think) all cards came with the same cable. Has anyone tried a custom cable that's longer than the standard cable? Any issues?
Reply 1 of 8, by Doornkaat
I can't tell you the max length but I made one long enough to leave two PCI slots between the cards. I had no problems using it but I didn't like the look so I shortened it to only leave one slot inbetween.😅
Reply 2 of 8, by Meatball
RaverX wrote on 2022-12-29, 15:19:
If you take a look at the Canopus Pure3D II Voodoo2's, those come from the factory with much longer cables since the SLI connectors are relocated toward the center of the PCB. So, if you build a quality cable it will be fine.
http://www.thedodgegarage.com/3dfx/boxes/box_ … _pure3d2_lx.jpg
***->WINNER, 1ST PLACE<-***
2022 #QUAKE3totheMAX -560.5fps-
Brain Drain Retro LAN https://discord.com/channels/799008837918261328
Windows ME
NForce2 A7N8X-E DLX
Athlon 848/154MHz
DDR@411MHz (2-3-3-3)
GeForce 256 DDR@144/344MHz
ESS Maestr0-1
Reply 3 of 8, by Sphere478
file.php?id=153677&mode=view
file.php?id=153678&mode=view
How long do you need it? How many slot spaces?
Could make a longer version.
Re: 3Dfx Voodoo 2 PCB SLI Bridge / SLI Cable
Alternately, you may be able to use a modified (twisted) 80-“pin” ide cable if you found a 34 pin (2x17) connector for it.
Or a modified (twisted) floppy cable.
I think the pcb is by far the best way though.
Sphere's PCB projects.
Reply 4 of 8, by RaverX
Sphere478 wrote on 2022-12-29, 18:48:
About 20 cm... The cards are not installed in a standard motherboard, there's a pci "riser" and I have pci slots on both sides and I want to use both sides. That way I can see a side for each V2 card.
Reply 6 of 8, by Sphere478
Yeah, sounds like a modified standard floppy cable is gonna be the way this goes 😀
RaverX wrote on 2022-12-29, 19:38:
Ah ,Post pics so we can see what you are working with.
Reply 8 of 8, by Sphere478
Okay, makes sense now. Yeah try reconfiguring a old floppy cable! 😀
