First post, by theelf
- Oldbie
Hi!!!
I add a PCI Cirrus Logic graphic card to output 15khz to my PC. My main card is a AGP riva 128
In VGATV readme, there is a option for a secondary card
http://mirrors.arcadecontrols.com/VGATV/pwp.n … bo.pt/pscoelho/
/S:<n> - With the new PCI/AGP VGA card detection it becomes possible to exist 2 or more video cards on the same syste […]
exist 2 or more video cards on the same system. While VGATV will
only use the card defined as primary card on BIOS, VGATV might not
detect that video card because it scans the PCI/AGP bus first and
will detect the first card that it supports, which might not be the
primary one. This switch will make VGATV ignore (skip) <n> video
cards before using the next detected one. This only works for PCI/
AGP cards, on which bus can reside more than one VGA card.
I try every option, but no luck... for example
vgatv /S:1 /NTSC
vgatv /S:1 /NTSC /CIRRUS
vgatv /S:2 /NTSC
vgatv /S:3 /NTSC
vgatv /S:1 /NTSC / etc etc
nothing vgatv always use my AGP card to change to 15khz!!
Any ideas? someone use vgatv with second graphic card? or maybe iI understand bad the option, and there is no way to output to secondary card?
THANKS!!!
