First post, by Msciej
I am using one of my old laptops, it has DOS 6.22 on it. The laptop has an external VGA port, how can I use it? I would like to use my external monitor, but whatever i try, the main inbuilt screen is the only one that works. Is there a DOS driver or will it require hardware rewireing? Obviously, it works fine when running windows. I dont need any dual/extended display.
