First post, by luisile
Hi all this is another question to my lasz post about my non working asus silent hd3650 agp. The bios is bad on this thing a suppose the chip itself is bad. BUT How that that when i read the memory chip on another working card ,also pm25lv512 the dump is diferent from the bios rom file that i can found on the internet? I left here in atechement files that i read with external programmer and a rom file from internet for the working hd2600pro. they are totaly diferent. What can i doo to resurect the hd3650 agp?
    hd2600 pro PM25LV512@SOP8.zip
    49.13 KiB
    32 downloads
    Bin file readed with tl866II pro
    Sapphire.HD2600Pro.512.070530.zip
    37.85 KiB
    36 downloads
    Bios rom downloaded 2600pro
Reply 1 of 13, by shevalier
https://www.techpowerup.com/vgabios/?architec … memSize=&since=
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Diamond monster sound MX300
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value
Reply 2 of 13, by Minutemanqvs
Is it this card?
I just got one, if it's of any use I can dump my bios chip from GPU-Z next week if it's possible.
Ah, shevalier beat me to it 😀
You should try booing your Windows with a PCI graphic card.
Searching a Nexgen Nx586 with FPU, PM me if you have one. I have some Athlon MP systems and cookies.
Reply 3 of 13, by luisile
Minutemanqvs wrote on 2023-05-08, 14:06:
Is it this card? […]
Is it this card?
Yes it is this card and i Would be very grateful if you dump the bios from gpu-z.
thanks
The problem is the system doesn not even post with this card now.
Reply 4 of 13, by Minutemanqvs
But meanwhile, can you boot your PC at least with a PCI graphic card? If so:
- Connect your PCI card
- Set your BIOS to boot from PCI first
- Add your broken AGP card
It could let you boot to Windows this way. If so, try reflashing the Radeon BIOS.
Reply 5 of 13, by luisile
Minutemanqvs wrote on 2023-05-08, 15:04:
But meanwhile, can you boot your PC at least with a PCI graphic card? If so: - Connect your PCI card - Set your BIOS to boot fro […]
Yes i can. i have a pci vga. but will it work? because now the vga bios chip is basicaly empty?
Reply 6 of 13, by Minutemanqvs
If you set your bios to boot from the PCI card, your dead AGP will just hopefully sit there doing nothing. Then you'll see if you have access to it to reflash it...you can try some BIOS linked by shevalier.
Reply 7 of 13, by Jo22
Switching VGA BIOSes was "easy" in the days before the Geforce FX series.
All it needed was a compatible BIOS and taking care of the stored speed settings (GPU, RAM).
There even were utilities to modify these settings.
By the mid 2000s, however, things got waaay more complicated.
The BIOS contained so many little settings like GPU core voltage, serial numbers, vendor IDs etc, making BIOS switching much more delicate.
Reply 8 of 13, by luisile
Jo22 wrote on 2023-05-08, 17:24:
Switching VGA BIOSes was "easy" in the days before the Geforce FX series. All it needed was a compatible BIOS and taking care of […]
What has this to do with my problem?
Reply 9 of 13, by Jo22
luisile wrote on 2023-05-08, 17:25:
I don't understand your question. 🤷‍♂️
I was trying to point out why BIOS flashing is nolonger as easy as it used to be.
Ie, someone may needs the absolutely correct VGA BIOS to fix/upgrade a graphics card.
A VGA BIOS of a similar model perhaps isn't good enough.
Edit: But maybe I misunderstood what you're trying to do. 🤷‍♂️
Your first posting was hard for me to read, also because of the missing punctuation.
Reply 10 of 13, by luisile
Jo22 wrote on 2023-05-08, 17:29:
I don't understand your question. 🤷‍♂️ […]
I ask again What has this to do with my problem?
Reply 11 of 13, by Jo22
luisile wrote on 2023-05-08, 17:36:
Good question. What is your hardware problem, exactly? 🤷‍♂️
Reply 12 of 13, by luisile
Jo22 wrote on 2023-05-08, 17:40:
The bios chip itself is faulty. i need a dump but preferably what is done with external programmer. Why ? because when i read bios on another card(hd2600pro) the dump from external programmer and the dump what i have downloaded from internet they are not even close to be the same. everything is in the first post.
Reply 13 of 13, by shevalier
luisile wrote on 2023-05-08, 14:48:
thanks
This card?
https://www.classicvga.com/product-page/asus- … -512mb-ddr2-agp
113-AB50900-101?
See GPU-z screen, the second from end
https://www.techpowerup.com/vgabios/29899/asu … 3650-512-080222
