First post, by skaarg
Sorry wasn't sure if I should put in Video or Software. If it needs to be moved sorry to the mods!
I recently acquired a Mitsubishi TFW1105SKTFW which is apparently a Diamond Plus 100. It was at my local university's surplus sale a couple weeks ago and I was surprised how great of an image it has compared to my other 21" Trinitron which is a lot more worn.
The odd thing about this monitor is it says it supports touch. On the front it says it is a PrecisePoint with MicroTouch installed. On the back it has a small area labeled "TouchPort" where a serial cable comes out. I'm assuming I need some sort of driver or software to communicate with and function. Was curious if anyone has this software. Google and Internet Archive searches have yielded nothing other than standard TFW1105 drivers which is the exact same model as the non-touch version of this monitor. I'm sure it's not great, but it'd be fun to play around with such an oddity for a bit at least haha.
Reply 1 of 4, by PC Hoarder Patrol
skaarg wrote on 2023-05-22, 22:23:
Had a bit of a dig on Wayback myself, so hopefully some of this helps...
Think your monitors proper model no. may be PrecisePoint P1105P (bottom of this link https://web.archive.org/web/20000303063954fw_ … ouchscreen.html)
It uses a touchscreen from a company called MicroTouch (became part of 3M) and their driver packages for various platfoms under the TouchWare label. The latest for DOS / Windows appears to be v5.62 which you can get here https://web.archive.org/web/20010811113852/ht … nload/TW562.exe and legacy versions at this link https://web.archive.org/web/2001081112 ... rivers.htm
There are also some diagnostic utilities here https://web.archive.org/web/20010215040023/ht … 2_utilities.htm and documentation here (the DOS / Windows links seem dead) https://web.archive.org/web/20010414031006/ht … cumentation.htm
Reply 2 of 4, by skaarg
That is 100% it! I could not find that software for the life of me! Thank you for digging better than I did!
I used the few different calibration tools in the software, but I believe I've finally got it in a somewhat good place now! Tested it out with some desktop usage out of more curiosity than anything. Might try a game for laughs to see how or if it works at all haha.
https://twitter.com/Skaarg/status/1661187874635628549
Reply 3 of 4, by PC Hoarder Patrol
skaarg wrote on 2023-05-24, 01:56:
Glad to see you got the software working though, to my eye, the actual monitor itself is definitely the star!
Had some experience working on touchscreen support back in the early 90s, but that was for public access kiosk systems with a heavily tailored interface...can imagine it could become tired fairly quickly for general desktop use.
Reply 4 of 4, by skaarg
PC Hoarder Patrol wrote on 2023-05-24, 06:24:
It definitely is! Looks absolutely great at half brightness so I’m guessing it had low usage back when it was used by the university. My other 21” Trinitron looks dimmer at full brightness.
