First post, by mbarszcz
I picked up my first Voodoo Card (a STB BlackMagic Voodoo2 12MB) to try out some glide games and was disappointed to find that the output was a mess.
Whenever glide is active, the video output is messed up with a random red noise pattern across the image. It is worse in some areas than others. I tried it in Moto Racer and UT99 with very similar results.
I tried both the FastVoodoo2 4.0 and the latest reference drivers with no change.
Being new to the 3dfx world, is this some kind of driver/patch compatibility thing, or is this card busted (bad ram, bad ramdac, something else on the output)?
video
Reply 2 of 5, by appiah4
Photos of the card please, looks like bent legs making unwanted contact or lifted legs in one of the ICs.
Reply 3 of 5, by mbarszcz
I was able to spend some time looking at it tonight and here's what I learned (and a few things that didn't help)
First off, I attached a few pictures of the card to this reply.
My first thought was that perhaps it was a heat related issue, so I added some heatsinks to the 3 main chips. That definitely cooled them down some, but unfortunately didn't solve the "red static" problem. Probably not a bad idea for longevity though if I can get this fixed.
I found that if I touch the card in a specific spot right behind the second TMU, the "red static" problem gets worse. Strangely, its nowhere near the output side of the card.
https://imgur.com/a/8GHRNR3
I also noticed that the board had a bit of a bend in it, so I thought perhaps there were some questionable solder joints in that area, so I reflowed both TMUs and the frame buffer chip. I heard them "adjust" shall we say when I reflowed them, but no change. I then hand-reflowed the bypass caps and resistors behind the TMU, right where touching makes the difference, but still no change. I then touched the board in the same spot (physically), but through an electrically insulated material (digikey bag 🤣), and it didn't have the same effect. So it seems that the act of physically touching it with skin that seems like it is causing some kind of interference, like interference being capacitively coupled into the circuit. I took off a few of the 10uF SMD capacitors on the board to check them with my ESR meter and those checked out okay, so it doesn't seem to be bad caps.
Touching anywhere else on the board doesn't seem to have that effect, just that one particular spot
Reply 4 of 5, by appiah4
Left TMU, bottom left first 3 pins from the left are bent and cotacting each other it would seem, as I suspected. And now they also appear tl have a solid solder bridge from the reflow attempt.
Reply 5 of 5, by mbarszcz
It really does look like it in that picture, but they weren't bridged. It must have been the light reflecting or a piece of dust or something. Edit: it was the light, I went to take the same shot again and the light reflected in the same way, weird.
There were a few corner pins that were a little bent, but I checked them all and none of them were shorted against each other. I straightened them out just to rule that out, but that didn't help unfortunately. I also took a real close look with magnification at the pins on all the chips and the soldering all looks clean and not shorted, despite what my lousy phone pictures may show.
