First post, by bestemor
- Oldbie
So, being a total newb on this topic, I was wondering if someone could explain about how the limitations vs tearing work.
- Or rather more specific, what exactly does that 60hz line in this diagram actually mean ?
https://international.download.nvidia.com/web … VSync-2-650.png
I assume it is the max limit ("capacity"?) for the current monitor, e.g. 144hz (or 165hz etc) vs the 60hz in the diagram ? And not something else ?
https://geekflare.com/vsync-in-gaming/
VSync corrects this screen tearing by limiting the frame rate per the graphic card refresh rate. This reduces the number of frames per second, adjusting it according to the monitor’s capacity.
Say I turn the Vsync setting to 'on' (as adaptive does not work with Win7), will I be golden as long as the frame rates keep between 60-144 ?
(and that there will be stuttering if they go lower)
Sorry for the stupid questions, but I'm having a hard time finding available monitors with Gsync module installed.
(which supposedly would work wonders even with Windows7 - for reasons...)
