First post, by moog
What does this actually do? You know, this header above the VRAM chips.
So is this the SLI header? The only comment on SLI for the Voodoo 5500 I could find online is here: https://forums.tomshardware.com/threads/voodo … 5/#post-5993173
And it says "No". Then this guy comes along and uses it to make a quadruple SLI that utilizes 4 Voodoo 5500 cards: http://captains-workspace.com/?page_id=17
So what is this header?
What was its intended use case?
What can it be used for?
And why is it not covered in the Voodoo 5500 manual?
Eventually I found the real manual, but it's just as useless as the marketing pamphlet.
Finally, I found the Voodoo 5500 FAQ from 3dfx itself and there it says something that it's for Quantum3D's AAlchemy cards, which enables cross-board SLI for VSA-100 chips. From what I've gathered, Captain from captains-workspace.com used Quantum3D Mercury Brick module to connect 4x 5500 cards. What would be needed to get just 2 working together?
    Voodoo4-5_Quick_Install.pdf.part02.pdf
    5 MiB
    30 downloads
    The real manual. Still useless. Part 2/3, merge with cat
    Voodoo4-5_Quick_Install.pdf.part01.pdf
    5 MiB
    30 downloads
    The real manual. Still useless. Part 1/3, merge with cat
    Voodoo4-5_Quick_Install.pdf.part00.pdf
    5 MiB
    32 downloads
    The real manual. Still useless. Part 0/3, merge with cat
    voodoo5.pdf
    582 KiB
    34 downloads
    Bloody useless manual. "Marketing pamphlet" is a description more fitting
    1.36 MiB
    Mirrored from https://vgamuseum.ru/wp-content/gallery/3dfx-voodoo-5-5500/3dfx_voodoo5_5500_f.jpg
Audigy 2 ZS in FreeDOS
LinLin adapter documentation
+ various capacitor list threads
Reply 1 of 6, by moog
Posting the remainder of files.
    333.63 KiB
    Quantum3D 200SBi with the cross-board SLI module
    3dfx-faq-voodoo5_5500.zip
    8.44 KiB
    33 downloads
    Voodoo 5500 FAQ
    Voodoo4-5_Quick_Install.pdf.part03.pdf
    3.8 MiB
    30 downloads
    The real manual. Still useless. Part 3/3, merge with cat
Reply 2 of 6, by Joseph_Joestar
That looks like a standard VESA feature connector to me.
They were used for DVD decoder cards and such back in the day. More info here: VESA feature connector devices
Reply 4 of 6, by moog
paradigital wrote on 2023-09-15, 12:58:
Read the last sentence on the linked captains-workspace page. It was an April Fool’s joke, nothing more.
BLOODY HELL
Joseph_Joestar wrote on 2023-09-15, 11:24:
Is it even remotely possible that this could be used to create a DVI output?
Reply 5 of 6, by Joseph_Joestar
moog wrote on 2023-09-15, 14:08:
You'd have to ask someone who's more familiar with the hardware specs.
I just happen to know what it was used for thanks to old computer magazines from the late '90s. 😀
Reply 6 of 6, by DerBaum
Yes. CRT Terminator Digital VGA Feature Card ISA DV1000
FCKGW-RHQQ2
