First post, by DoZator
The GeForce 6500 and GeForce 6200 (Gigabyte GV-N62256DP2-RH) came with a CD driver containing ForceWare 76.45 for Windows 9x. But now I can't find on the Internet either a CD image containing this version of the driver, or even at least the driver separately. The disk with this driver looks like this:
Information confirming the existence of this driver version for Windows 98 can be found there:
https://web.archive.org/web/20160603100358/ht … 17/kg61723.html
https://msfn.org/board/topic/136484-problems- … ce-6200-driver/
https://zhidao.baidu.com/question/7177686.html
I want to test video cards with this driver version.
Reply 1 of 6, by Duffman
I'm not sure if the driver version you're referring to ever existed for windows 98, it may have been an XP only thing.
https://www.nvidia.com/en-gb/drivers/win9x-archive/
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 3 of 6, by DoZator
On the other hand, for some reason it is very hard to believe that ALL THREE independent sources are lying at once. Yes, and photos of the original GIGABYTE CDs for these video cards, on which support for 9x is clearly indicated, makes you somewhat doubtful. Unfortunately, we won't find out the truth until we find this disk.
Here are more examples of photos of such CDs for Gigabyte 6-series video cards, where the presence of a driver for Windows 98 is explicitly indicated:
128Mb <PCI-E> DDR2 GIGABYTE GV-NX65128D (OEM)64bit D-Sub+DVI+TV Out <GeForce 6500>
https://www.nix.ru/autocatalog/gigabyte/video … 3.html#pid=2247
https://static.nix.ru/images/gigabyte-gv-nx65 … ft&view_id=2247
256Mb <AGP> DDR2 GIGABYTE GV-N62256DP2-RH (OEM) 64bit DVI+TV Out <GeForce 6200>
https://www.nix.ru/autocatalog/gigabyte/video … 9.html#pid=2247
https://static.nix.ru/images/gigabyte-gv-n662 … ft&view_id=2247
256Mb <PCI-E> DDR2 GIGABYTE GV-NX66T256DE (RTL) D-Sub+DVI+TV Out+SLI <GeForce 6600GT>
https://www.nix.ru/autocatalog/gigabyte/video … 7.html#pid=2247
https://static.nix.ru/images/gigabyte-gv-nx66 … ft&view_id=2247
256Mb <PCI-E> GDDR3 GIGABYTE GV-NX68G256D-B (OEM) D-Sub+DVI+TV In/Out+SLI <GeForce 6800GS>
https://static.nix.ru/images/gigabyte-gv-nx68 … ft&view_id=2247
It turns out that even on later revisions of disks (Up to version 4.1), they kept a mention of Windows 9x support. And this is most likely not an error. And although none of these disks can be found on the Internet anymore, the first one is still interesting (For GeForce 6500\6200LE), because there is a high probability that the driver you are looking for is there.
Maybe there is some website on the Internet where collectors of old video cards live, from whom you could ask about the presence of such CDs in their extensive collections?
Reply 4 of 6, by Duffman
I do have the driver CD for the gigabyte 6600GT. Never thought to upload it as the drivers are already online.
I know The 6000 series does support windows 98. I forget which version added support, last 81.98 should work.
There was no 76.45 version for 98 as far as I can tell though.
CPU: Ryzen 9 5950X
Reply 5 of 6, by BitWrangler
Nearest version for 98 that I am turning up is... https://www.techspot.com/drivers/driver/file/ … formation/5437/
Reply 6 of 6, by DoZator
I wonder what version is on your CD and what exactly it looks like? It is known for certain that they soon removed Win9x support from later CD releases (removing the mention of 9x from the cover). Another caveat is that the GeForce 6600GT (NV43) and GeForce 6500 (NV44) were released with some time difference. Therefore, it is quite logical that the GeForce 6500 is equipped with the most recent and up-to-date driver at that time, since 77.72 did not exist at that time under 9x. The Internet archive, unfortunately, did not save the download page for GF6500\6200LE, but for all other cards under 9x, 76.44 from other 6-series cards was relevant for a long time, until the release of 77.72. 76.45 may not have been available for download, but it may have been available exclusively on CD. It is very unlikely that three people from different parts of the world made the same typo at once. What evidence suggests otherwise? In any case, only the real owner of the GeForce 6500 with the original CD, as in the first picture, will be able to put an end to this issue.
